Re: RE: Running PPPD daemon
04/23/2009 10:12 AM
post27883
Hi
I am looking at starting pppd from an applicaition, so i am trying on the spawn suggestion ..but when i gone throguh
pppd docuemntation it says ..
" If you spawn pppd from another program and specify the nodetach or updetach option, and if a signal is dropped on pppd
while it's running a connect or disconnect script, pppd raises the signal on the entire process group, including the
parent (i.e. the program that spawned pppd). This could cause the parent to terminate unexpectedly "
through command line i am using
pppd /dev/ser1 115200 ip1:ip2 debug updetach ... so
1. when i spawncan i not use updetach ?
2. Also let me know the method/code through which i can sfaely terminate from my parent process in case ppp
communciation fails.
Ravi
> Or maybe "how do I automatically start it up" (as in putting the command
> in something like rc.local).
> So many interpretations :>.
> R.
> From: Weijie Zhang [mailto:community-noreply@qnx.com]
> Sent: Thursday, April 23, 2009 9:42 AM
> To: general-networking
> Subject: RE: Running PPPD daemon
> I think his last sentence is saying he wants to know the utilities that
> invoke pppd other than through command line.
> If you are running photon, there is a utility called "phlip". Simply run
> the phlip, a networking configuration window pops up and at its
> connection page, you can add a new connection method and choose the Type
> of Serial and the device and then do the rest accordingly. The phlip
> will invoke pppd according to your configuration.
> As you said you are testing the ppp communcation, I think you'd better
> contiune to use the way of command line as this way gives you the full
> control of configuration.
> Thanks.
> Weijie
> From: Sean Boudreau [mailto:community-noreply@qnx.com]
> Sent: April 23, 2009 9:08 AM
> Subject: Re: Running PPPD daemon
> On Thu, Apr 23, 2009 at 03:31:46AM -0400, ravi varma wrote:
> > Hi
> > RIght now i am testing PPP communication between two PC'S by doing
> > pppd /dev/ser1 115200 ip1:ip2 on command line ..or else keep the same
> statement in string and call system(string) ..so that affect is same.
> > I want to know other approcahes of enabling PPPd Other than from
> command line and system command.
> There's the spawn() family of libc calls. I'm not sure I understand the
> question...
> -seanb
> http://community.qnx.com/sf/go/post27870
> http://community.qnx.com/sf/go/post27877
