Forum Topic - Why does launching inetd create a zombie process?:
Hi:
We use the following script in our buildifs for starting up our network related resources:
ifconfig en0 10.13.129.77 netmask 255.255.252.0
route add 0.0.0.0 10.13.128.2
inetd /etc/inetd.conf &
If I instrument the above script with 'pidin' calls before and after the inetd calls, I  notice that a zombie process
seems to get created:
pidin -F "%a %60N %e"
 155673 bin/sh                                                          1
 159771 proc/boot/io-net                                           1
 172058 proc/boot/esh                                              155673
 188444 (Zombie)                                                     172058
 188445 proc/boot/pidin                                            172058
 188446 proc/boot/inetd                                           188444
The third column is the parent PID. As you can see the Zombie is owned by esh which runs the network init script. Esh in
 turn is spawned by the sh command which is launched by yet another higher level script in the buildifs.
After a short time, the zombie get taken over by the kernel and cleaned up some time later. However, in the meantime the
 existance of a zombie process causes other problems with our software.
Any idea what this zombie process is and why it gets created? I tried removing the ampersand when launching and it
resolves the zombie creation problem however the inetd process is now stuck in a SIGSUSPEND state.
Re: Why does launching inetd create a zombie process?
On Fri, Mar 27, 2009 at 02:49:43PM -0400, Robert D'Attilio wrote:
> Hi:
>  155673 bin/sh                                                          1
in turn is spawned by the sh command which is launched by yet another higher level script in the buildifs.
the existance of a zombie process causes other problems with our software.
I suspect the zombie is some artifact of using esh.  The SIGUSPEND is
entered when inetd doesn't have any sockets to listen on (nothing to
do).   Try 'inetd -d' (no ampersand) and see what it reports.
RE: Why does launching inetd create a zombie process?
Sean:
Substituting 'inetd -d' for 'inetd &' in my ip startup script ends up
hanging the startup script and I cannot telnet into the card because
inetd is not running or hung itself. I can still ping the card though.
From: Sean Boudreau [mailto:community-noreply@qnx.com]
Sent: Monday, March 30, 2009 11:29 AM
To: general-networking
Subject: Re: Why does launching inetd create a zombie process?
> Hi:
the inetd calls, I  notice that a zombie process seems to get created:
>  155673 bin/sh
1
155673
>  188444 (Zombie)
172058
172058
188444
by esh which runs the network init script. Esh in turn is spawned by the
buildifs.
cleaned up some time later. However, in the meantime the existance of a
removing the ampersand when launching and it resolves the zombie
state.
General
http://community.qnx.com/sf/go/post25557
On Mon, Mar 30, 2009 at 12:16:02PM -0400, Robert D'Attilio wrote:
> Sean:
-d is a debug flag.  One wouldn't use it in the field but I'm
curious as to what it spits out.  I suspect there's something wrong
with your inetd.conf file or you don't have perms to bind ...
Started inetd -d from the command line and it spits out
# inetd -d /etc/inetd.conf
ADD : 3000 proto=tcp, wait:max=0.40, user:group=root. builtin=0
server=/bin/telnetd policy=
registered /bin/telnetd on 4
But it sits in the foreground now and takes over the shell (what I would
expect I guess since not putting it in the background with '&').
Sent: Monday, March 30, 2009 12:19 PM
> Sean:
General
http://community.qnx.com/sf/go/post25570
______________________________________________________________________
This email has been scanned by the MessageLabs Email Security System.
For more information please visit http://www.messagelabs.com/email
Re: RE: Why does launching inetd create a zombie process?
So in this case it looks like telnet was added
successfully so presumably this instance isn't in
SIGSUSPEND.  Do any differences come to mind
between this method and the way it's started
from your startup script?
RE: RE: Why does launching inetd create a zombie process?
The only difference is I manually invoked the following from the
command-line rather than from within a script:
# io-net -dppc405 mac=00019c00266e -ptcpip &
# ifconfig en0 10.13.129.77 netmask 255.255.252.0
# route add 0.0.0.0 10.13.128.2
# inetd /etc/inetd.conf
For reference here are scripts used for starting the network components
from within our buildifs. /scripts/ip_config kicks everything off and is
called from within the .script section of the buildifs.
Contents of buildifs:
	[perms=+x] /scripts/ip_config = {
	#!/bin/sh
	if [ -e /doc/mac_dbm_init ]
	then
  		echo macdbminit
  		esh /doc/mac_dbm_init
	else
  		echo macinit
  		esh /tmp/mac_init
	fi
	commonSlWaitForPro /dev/socket
	if [ -e /doc/ip_dbm_init ]
	then
  		echo ipdbminit
  		esh /doc/ip_dbm_init
	else
  		echo ipinit
  		esh /tmp/ip_init
	fi
Contents of /doc/mac_dbm_int:
Contents of /doc/ip_dbm_init:
I tried using just the regular shell (/bin/sh) instead of esh for
launching the two sub-scripts and I don't see the zombie but the console
spews out some garbled logs about 'something' not being found (I can't
decipher it - it's as if two processes are writing to the console at the
same time). However, the IP stack and inetd daemon appear to be working.
I'm thinking the garbled log is due to my syntax trying to invoke the
two subshells?
Robert
Sent: Tuesday, March 31, 2009 9:43 AM
Subject: Re: RE: Why does launching inetd create a zombie process?
would
General
http://community.qnx.com/sf/go/post25643
> 	#!/bin/sh
> 	then
>   		echo macdbminit
> 	else
>   		echo macinit
>   		esh /tmp/mac_init
> 	fi
> 	then
>   		echo ipdbminit
> 	else
>   		echo ipinit
>   		esh /tmp/ip_init
> 	fi
Shouldn't need the ampersand above.
	waitfor /dev/socket/2
	if_up -p en0
again, shouldn't need the ampersand above.
> two subshells?
> Robert
> would
> -seanb
> http://community.qnx.com/sf/go/post25651
I wonder if there's some sort of race condition in there.
There should probably be a "waitfor /dev/io-net/en0 4" after the io-net
command and an "if_up en0" after the ifconfig.
	R.
From: Robert D'Attilio [mailto:community-noreply@qnx.com]
Sent: Tuesday, March 31, 2009 10:15 AM
Subject: RE: RE: Why does launching inetd create a zombie process?
# io-net -dppc405 mac=00019c00266e -ptcpip & # ifconfig en0 10.13.129.77
netmask 255.255.252.0 # route add 0.0.0.0 10.13.128.2 # inetd
/etc/inetd.conf
	#!/bin/sh
	then
  		echo macdbminit
	else
  		echo macinit
  		esh /tmp/mac_init
	fi
	then
  		echo ipdbminit
	else
  		echo ipinit
  		esh /tmp/ip_init
	fi
two subshells?
Robert
> server=/bin/telnetd policy= registered /bin/telnetd on 4
would
So in this case it looks like telnet was added successfully so
presumably this instance isn't in SIGSUSPEND.  Do any differences come
to mind between this method and the way it's started from your startup
script?
General
General
"pidin fam" will tell you who is the parent of the zombie, that would
probably give you an idea.
-xtang
> From: Robert Craig [mailto:community-noreply@qnx.com]
> Sent: Tuesday, March 31, 2009 10:25 AM
> the io-net command and an "if_up en0" after the ifconfig.
> 	R.
> the command-line rather than from within a script:
> 10.13.129.77 netmask 255.255.252.0 # route add 0.0.0.0
> 10.13.128.2 # inetd /etc/inetd.conf
> components from within our buildifs. /scripts/ip_config kicks
> everything off and is called from within the .script section
> of the buildifs.
> 	#!/bin/sh
> 	then
>   		echo macdbminit
> 	else
>   		echo macinit
>   		esh /tmp/mac_init
> 	fi
> 	then
>   		echo ipdbminit
> 	else
>   		echo ipinit
>   		esh /tmp/ip_init
> 	fi
> for launching the two sub-scripts and I don't see the zombie
> but the console spews out some garbled logs about 'something'
> not being found (I can't decipher it - it's as if two
> processes are writing to the console at the same time).
> invoke the two subshells?
> Robert
> would
> so presumably this instance isn't in SIGSUSPEND.  Do any
> differences come to mind between this method and the way it's
> started from your startup script?
> -seanb
