11/10/2008 12:36 PM
post16318
I am trying to use a Flash streaming media server in live mode by connecting a webcam to the PC. I can run the example
livedemo fla file on my PC. I can see the live video feed from the Flash Media server, however when I run this file(swf
file) on our target(simplified QNX 6.3.2 with Flash Lite 3.0), we don't see the video but everything else. When we
turned on the verbose error we see the following two errors:
# flash-gf -L2 -vvv -f flashlite-565.so -A 1 liveMedia1.swf
1 ((1) main) FL3 not audio device card -1, device 0
1 ((1) main) GetSecuritySandbox: /hmi/liveMedia1.swf security 1
trace("rtmp://192.168.2.101/live/livestream")
3 ((6) xmlsocket) FL3 xmlsocket_thread: line 80 connect() failed, errno 26 0, will retry
3 ((6) xmlsocket) FL3 xmlsocket_thread: line 97 socket/connect failed, err no 260, will notify
The first error is because we do not have a audio card on our Flash Media Server, but I do not beleive that should stop
us from getting the video since we can see the video on the PC.
Any ideas, what could be wrong?
Thanks!
RE: Flash Player: Live video
11/10/2008 12:41 PM
post16320
I'm not quite sure where to go with this one. This is an error
condition being reported by an application using networking and not a
networking application per se.
What does ifconfig report?
Can you ping the host that you're trying to connect to?
Is networking working in general or is it just this app that is failing?
From: Yogesh Patil [mailto:community-noreply@qnx.com]
Sent: Monday, November 10, 2008 12:37 PM
To: general-networking
Subject: Flash Player: Live video
connecting a webcam to the PC. I can run the example livedemo fla file
however when I run this file(swf file) on our target(simplified QNX
When we turned on the verbose error we see the following two errors:
Media Server, but I do not beleive that should stop us from getting the
Thanks!
General
http://community.qnx.com/sf/go/post16318
Re: RE: Flash Player: Live video
11/10/2008 1:03 PM
post16323
Thanks Robert! for your quick reply,
Networking works in general, I can ping to IP addresses. I can also ping to the host server, it is just this app doesn't
seem to connect.
Here's what ifconfig reports:
# ifconfig
lo0: flags=8009<UP,LOOPBACK,MULTICAST> mtu 33212
capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
enabled=0<>
en0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
address: 00:0e:99:02:60:e9
inet 192.168.2.110 netmask 0xffffff00 broadcast 192.168.2.255
11/10/2008 1:06 PM
post16325
doesn't seem to connect.
> # ifconfig
> enabled=0<>
> Thanks
If you slay / restart the app does it work. Was connectivity
established after the app was started?
11/10/2008 5:39 PM
post16353
It didn't help even after restarting the app...I have attached the sample actionscript file if it helps..
I think it could be some networking/security issue as the error indicates some security code...
11/10/2008 5:42 PM
post16354
It says above Flash Lite xmlsocket thread failed to connect...any ideas...
11/10/2008 5:47 PM
post16356
errno 260 is ETIMEDOUT. Is the other end up?
11/11/2008 11:12 AM
post16397
Yes the other end is up..
11/11/2008 11:28 AM
post16398
Well it doesn't appear to be accepting tcp connections...
