RE: strange hostname on QNX 6.2.1
09/29/2008 9:20 AM
post14162
re: mysterious dot after hostname
There was a PR about this. This occurs because you
have explicitly set the domain to be a null string,
and once the domain is set, it cannot be "unset" to
it's original, unset state (this is a feature of setconf).
If you don't set the domain, or the domains are the same
(recommended) then you will not see the dot.
I think this was fixed at some point to get rid of the
dot, when you explicitly set the domain to be a null
string.
Most of us just set the domain (the same) on all our
machines.
aboyd
