RE: Installing ssh on target without graphic interface
09/16/2008 11:04 AM
post13482
Have you compared the mode of the files on your host (on which you
successfully installed the ssh) and on the target after you copied them
over?
When you say it doesn't work, what is the problem?
I don't think you need a graphic interface to configure your server on
the target.
Weijie
Sent: September 16, 2008 10:51 AM
To: general-networking
Subject: Installing ssh on target without graphic interface
Hi all,
I have a very simplified version of QNX6.3.2 on the target. Due to the
need of remote control and file access, i would like to install the ssh
on it. But it has no graphical interface. It has internet access. How
could i do this?
I have tried one way like this: i successfully installed ssh on on fully
installed qnx6.3.2 via internet. I just copied the relevant files to the
target. But could not work.
Another way out is since i installed ssh on my full-versioned qnx via
internet update, is it possible that i copy the source package to the
target? And then install there on the target? But i have no ideas where
i located the downloaded packages for ssh.
Thank you
Eric
General
http://community.qnx.com/sf/go/post13479
Re: Installing ssh on target without graphic interface
09/16/2008 11:18 AM
post13485
On Tue, Sep 16, 2008 at 10:51:07AM -0400, Eric Dong wrote:
> Hi all,
> I have a very simplified version of QNX6.3.2 on the target. Due to the need of remote control and file access, i would
like to install the ssh on it. But it has no graphical interface. It has internet access. How could i do this?
> I have tried one way like this: i successfully installed ssh on on fully installed qnx6.3.2 via internet. I just
copied the relevant files to the target. But could not work.
> Another way out is since i installed ssh on my full-versioned qnx via internet update, is it possible that i copy the
source package to the target? And then install there on the target? But i have no ideas where i located the downloaded
packages for ssh.
I'm guessing you're trying to install an old 3rd party package
and the graphical issue is due to qnxinstall needing photon?
I'm pretty sure there was a cli installer at some point but I can't
seem to find it. I'm not familiar with the old 3rd party packages.
It might be easier to look into building ssh from the networking
repo.
