Forum Topic - QNET on QNX 6.2.1 and QNX 6.4.0: (10 Items)
Hi Robert,
We have many old machines (x86) running QNX 6.2.1 and several new machines (x86) running QNX 6.3 SP3 with core-
networking 6.4 (planning) for its jumbo packets spport. My question is how to use QNET to connect the old and new
machines so that they can see each other and realise TDP on them?  We are planning to use a QNX 6.2.1 machine as a
server, which has some slave machines running either QNX 6.2.1 or the new QNX 6.4. In this way, we could keep our GUI
and still get some new features from io-pkt, jumbo package support for instance.  If it is possible, would you please
tell me how to set io-net and io-pkt to implement this? Thank you very much in advance! Kind regards, Jianbo
RE: QNET on QNX 6.2.1 and QNX 6.4.0
On the new machines, make sure that you specify
the "mtu_en=1496" option to qnet, so that it
creates packets which the old machines can receive.
aboyd
Hi Jianbo:
	I'm afraid that there is no mechanism in place today which will
allow a 6.2.1 version of TDP to communicate with the upcoming 6.4.0
release or with io-pkt.  Qnet-compat has been deprecated in this release
of networking.
	Robert.
From: Jianbo Zhang [mailto:community-noreply@qnx.com]
Sent: Tuesday, September 09, 2008 3:32 AM
To: general-networking
Subject: QNET on QNX 6.2.1 and QNX 6.4.0
Hi Robert,
machines (x86) running QNX 6.3 SP3 with core-networking 6.4 (planning)
the old and new machines so that they can see each other and realise TDP
on them?  We are planning to use a QNX 6.2.1 machine as a server, which
this way, we could keep our GUI and still get some new features from
you please tell me how to set io-net and io-pkt to implement this? Thank
General
http://community.qnx.com/sf/go/post13036
Not a very good solution, but if you are stuck...
Copy the io-net/npm-qnet-l4_lite.so from QNX6.4 to your QNX 6.2.1
machine, and
cross you finger to see if they are still running...
-xtang
> From: Robert Craig [mailto:community-noreply@qnx.com]
> Sent: Tuesday, September 09, 2008 10:48 AM
> Subject: RE: QNET on QNX 6.2.1 and QNX 6.4.0
> Hi Jianbo:
> which will allow a 6.2.1 version of TDP to communicate with
> the upcoming 6.4.0 release or with io-pkt.  Qnet-compat has
> been deprecated in this release of networking.
> 	Robert.
> Hi Robert,
> new machines (x86) running QNX 6.3 SP3 with core-networking
> how to use QNET to connect the old and new machines so that
> planning to use a QNX 6.2.1 machine as a server, which has
> 6.4. In this way, we could keep our GUI and still get some
>  If it is possible, would you please tell me how to set
> http://community.qnx.com/sf/go/post13053
I've got a funny feeling that there may have been some kernel API
changes which will break this pretty quickly, but you never know.:>
From: Xiaodan Tang [mailto:community-noreply@qnx.com]
Sent: Tuesday, September 09, 2008 1:09 PM
machine, and
-xtang
> Hi Jianbo:
> 	Robert.
> Hi Robert,
General
http://community.qnx.com/sf/go/post13078
Hmm..
If io-net is recompiled against 6.4.0, then it going to looking for
libc.so.3, which,
I am sure going to be a problem on 6.2.1 system.
Maybe io-net/npm-qnet-l4_lite.so from 6.3.0 is a better candidate.
-xtang
> Sent: Tuesday, September 09, 2008 1:11 PM
> API changes which will break this pretty quickly, but you
> never know.:>
> 6.2.1 machine, and cross you finger to see if they are still
> running...
> -xtang
> > Hi Jianbo:
> which will allow
> 6.4.0 release
> > or with io-pkt.  Qnet-compat has been deprecated in this release of
> > networking.
> > 	Robert.
> > Hi Robert,
> how to use
> > QNET to connect the old and new machines so that they can see each
> > machine as a server, which has some slave machines running
> either QNX
> GUI and still
> for instance.
> >  If it is possible, would you please tell me how to set io-net and
> > regards, Jianbo
> > General
> > General
> http://community.qnx.com/sf/go/post13079
Re: RE: QNET on QNX 6.2.1 and QNX 6.4.0
Many thanks for the prompt reply from all of you. It seems this is not an easy issue as I expected. However, it is not
possible for us to upgrade all our old machines from QNX 6.2.1 to QNX 6.3 or 6.4 either for many practical reasons. We
are still thinking to make the old machines somehow communicate with the new ones running QNX 6.4 for its new features.
If the TDP via QNET is not a good solution, how do you think about the TCP/IP socket-based IPC? Certainly, QNET is still
 our best choice if possible. Any suggestions or links to some resources on this issue are very appreciated. Jianbo.
RE: RE: QNET on QNX 6.2.1 and QNX 6.4.0
There was a version of lwl4 qnet that was compiled
some years ago for 6.2.1, and worked quite well, but
there wasn't enough interest to regress test and
release it, which sometimes seems to be 99% of the
job!
aboyd
I tried io-net/npm-qnet-compat from QNX 6.3.0 on the machine running QNX 6.4 pre-release version. Now two machines
running QNX 6.2.1 and QNX 6.4 can communicate each other. Hopefully I shall have no problems for TDP. Any other things
that I should be aware of ? Thanks, Jianbo
Hi Jianbo:
	The only problem with this is that you have to make sure that
the networking binaries that you use are all compatible with io-net.
You may well find that some 6.4 networking utilities are incompatible
with io-net.  In that case, just copy over the 6.3.2 binary.
	Robert.
Sent: Thursday, September 18, 2008 8:00 AM
Subject: Re: RE: QNET on QNX 6.2.1 and QNX 6.4.0
6.4 pre-release version. Now two machines running QNX 6.2.1 and QNX 6.4
Any other things that I should be aware of ? Thanks, Jianbo
General
http://community.qnx.com/sf/go/post13605
