Forum Topic - Communicating with PPP over serail link:
I am working on PPC platform, I was able to run PPP using the follwoing io-net commnad, besides TCP/IP stck.
io-net -i 1 -p tcpip -p pppmgr
Now i want to communciate PPP over serail link, and dont have pppd facility in target.
Let me know the way to do the same with socket program , or else is there any way to capture packets after PPP stack and
 then transmit the same through serail link.
Ravi
RE: Communicating with PPP over serail link
You have to have pppd running on your target in order to have PPP link
(both link layer and network layer, i.e. ip) established and then do the
communication as usual. So you have to have pppd facility in target.
Thanks.
Weijie
From: ravi varma [mailto:community-noreply@qnx.com]
Sent: August 14, 2008 8:24 AM
To: general-networking
Subject: Communicating with PPP over serail link
facility in target.
there any way to capture packets after PPP stack and then transmit the
Ravi
General
http://community.qnx.com/sf/go/post11781
Re: RE: Communicating with PPP over serail link
What commands are reuiqred to add PPPD on to my build.
Ravi
> Thanks.
> Weijie
> facility in target.
> Ravi
I got it running by adding pppd in my build file..thanks for giving clarity that pppd is must to run.
> Ravi
> > Thanks.
> > Weijie
> > facility in target.
> > Ravi
> > General
Hi
I need to communicate between virtual PC and target through PPP over serail link, for that i invoked PPPD on both and
was able to ping between them.
i used the commands :
pppd /dev/ser1 ip1:ip2    ---- from sever
pppd /dev/ser1 .....at client side
after which ip are configured and i am able to ping. Now when i wnat to communciate through program i did following
int fd; char buffer[2]="ab";
fd = open("/dev/ser2", O_RDWR | O_NOCTTY | O_NDELAY);
while(1)
		write(fd, buffer,2);
		sleep(1);
} ..... on the tranmission side and in a  similar fashion for receving on the reception side.
I am not receieving the data  (I am sure that program is working fine, as i tested the same with put invoking PPP)...
what commands i need to used to open my serail port so taht data will be passed over PPP.
Ravi
> > Ravi
> > > Thanks.
> > > Weijie
> > > facility in target.
> > > Ravi
> > > General
Can any one send me program for Transmitting/receing data PPP over serail port, do i need to do that through scoket
program. Please read my earlier message for more information.
> Hi
> link, for that i invoked PPPD on both and was able to ping between them.
> while(1)
> 		sleep(1);
> reception side.
> tested the same with put invoking PPP)... what commands i need to used to open
> Ravi
> > > Ravi
> > > > Thanks.
> > > > Weijie
> > > > facility in target.
> > > > Ravi
> > > > General
If you've successfully set up pppd (which you have since you
can ping) you need to use sockets.  If you just want to send
raw data you don't need any networking at all and can use
open("/dev/ser1", ...).  I'd suggest sockets since you've
come this far.
There's lot of socket programing resources out there; for
example:
http://beej.us/guide/bgnet/
> > Hi
> > while(1)
> > 		sleep(1);
> > reception side.
> > Ravi
> > > > Ravi
> > > > > Thanks.
> > > > > Weijie
> > > > > facility in target.
> > > > > Ravi
> > > > > General
