using sendmsg/sendmmsg for data link layer packets
03/11/2023 6:34 AM
post122159
i have written an application which runs under QNX version 7.1.0 to send raw Ethernet frames using BPF interface. The
application constructs the Ethernet frame and send it using the write() function, it is working fine.
Since the number of frames that we need to send are really large, by using the write() function it takes long time and
the throughput is very low.
Therefore I consider using the sendmsg (mainly sendmmsg) to send large chunks of frames in one shot. However these
functions are not working with BPF interface and throws the error "Socket operation on non-socket".
Here is the used code snippet:
std::vector<uint8_t> m_buffer = ...;
struct msghdr snd_msg;
unsigned char dst_addr[6] = {0x11, 0x11, 0x11, 0x11, 0x11, 0x11};
struct iovec snd_iov[1];
snd_iov[0].iov_base = m_buffer.data();
snd_iov[0].iov_len = m_buffer.size();
snd_msg.msg_name = dst_addr;
snd_msg.msg_namelen = 6;
snd_msg.msg_iov = snd_iov;
snd_msg.msg_iovlen = 1;
snd_msg.msg_control = 0;
snd_msg.msg_controllen = 0;
ssize_t bytes_sent = sendmsg(m_socketFd, &snd_msg, 0);
if (bytes_sent == -1) {
std::cerr << "sendmsg failed: " << strerror(errno) << "\n";
} else if (bytes_sent != m_buffer.size()) {
std::cerr << "could not send all data: " << bytes_sent << "\n";
} else {
std::cout << "sent all data\n";
The error msg:
# /tmp/send
sendmsg failed: Socket operation on non-socket
What is the standard solution to send multiple raw Ethernet frames in QNX?
