Forum Topic - rpcbind got "Permission denied" error.:
hi,
I am running rpcbind on my board. but got  "Permission denied" errors.
# ./rpcbind -d
rpcbind: Cannot bind `local': Permission denied
rpcbind: Failed to open /var/run/rpcbind.sock: Permission denied
# ls -l
total 6796
-rwx------   1 root      root          56752 Sep 02  2019 rpcbind
and   /var/run/ also writable:
# ls -l /var
total 56
drwxrw-rw-   2 root      root           4096 Jan 01 00:08 run
How can I fix it? thanks.
Version: QNX 7.0
Re: rpcbind got "Permission denied" error.
Two thoughts:
1) Is /var/run on a standard qnx6 type filesystem? Or is it on something else?
2) What permissions is io-pkt running with - are you dropping root or using some other security setup? io-pkt will
create the socket in /var/run when rpcbind does the bind() call.
