Forum Topic - Iso image:
Iso image
Hi
I would like to run a QNX on ARM on a virtual machine
I think that QEMU could work https://www.qemu.org/
QEMU need an iso file to run.
How can i create an QNX ARM iso image file ?
I can create an ARM image file with momentics, but the resulting image file is a .ifs image
How to convert .ifs file to .iso file ?
Is it the right way to do ?
Olivier
Re: Iso image
The .ifs file is good for QEMU, just pass it in as the kernel. Here's the qemu command I use to startup a qemu running
QNX where arm.ifs is the .ifs file you have built.
qemu-system-arm -machine vexpress-a15 -cpu cortex-a15 -m 1G -kernel arm.ifs  -nographic -serial mon:stdio
You will need to ensure that your build file builds the correct type of ifs:
[image=0x80000000]
[virtual=armle-v7,elf +compress] boot = {
    startup-armv8_fm
    PATH=/proc/boot:/sbin:/bin:/usr/bin:/usr/sbin LD_LIBRARY_PATH=/proc/boot:/lib:/usr/lib:/lib/dll:/lib/dll/pci
CONFIG_PATH=/proc/boot:/etc procnto-smp-instr
I also have an fs built in to a qcow image running on a virtio block driver and a virtio network driver with these
additional options on the qemu command line:
-drive file=armfs.qcow2,if=none,id=drv0 -device virtio-blk-device,drive=drv0 -netdev bridge,br=virbr0,id=net0 -device
virtio-net-device,netdev=net0,mac=$MACADDR
Note that the startup-armv8_fm and virtio drivers are part of the virtio extras package in SDP7.0.0 and not part of the
base SDP7 install.
Re: Iso image
Thank for your answer
I tried this but i doesnt have startup-armv8_fm
i doesnt have "extras package in SDP7.0.0"
Where is this package ?
I m on a Windows host of QNX650
Thank
Olivier
Re: Iso image
Sorry but that's a 7.0.0 package and not available in 6.5.0. You may need to come up with your own startup in 6.5.0.
Also note that QEMU works a lot better under Linux than under Windows if you do get a working ifs.
