Forum Topic - Cellular modem and PPP:
We have an Beaglebone LTE cellular modem cape from Nimbelink. Using the instructions for setting up PPP on Linux (see
http://nimbelink.com/wp-content/uploads/2015/11/Skywire-PPPd-for-LTE-Application-Note.pdf) the modem works as expected.
Tried the same thing under QNX 6.5 and have had no luck. Command that we run and scripts are below. Any suggestions?
Nothing shows up in the syslog to give any clues as to why it does not work.
Thanks in advance,
Todd
# pppd call verizon
Connect script failed
# cat /etc/ppp/peers/verizon
/dev/serusb6
115200
connect "/fs/emmc/usr/bin/chat v -V f /fs/emmc/etc/ppp/peers/verizon chat"
noauth
defaultroute
usepeerdns
local
debug
updetach
# cat /etc/ppp/peers/verizon-chat
TIMEOUT 35
ECHO ON
ABORT '\nBUSY\r'
ABORT '\nERROR\r'
ABORT '\nNO ANSWER\r'
ABORT '\nNO CARRIER\r'
ABORT '\nNO DIALTONE\r'
ABORT '\nRINGING\r\n\r\nRINGING\r'
'' \rATZ
OK 'ATQ0 V1 E1 S0=0 &C1 &D2 +FCLASS=0'
OK AT+CGDCONT=3,"IP","vzwinternet","0.0.0.0",0,0
OK ATD*99***3#
CONNECT ''
Re: Cellular modem and PPP
As per my experience, First of all you have to check which chipset is used by modem?
Then check QNX have native driver for that chipset.
If it is, QNX will automatically give response.
What is aim behind this all stuff?
I was trying to send data wirelessly. In it, I can help you.
The modem itself communicates over UART, so the chipset is not the problem. PPP does not work the same as it does on
Linux. We have decided to port the same PPP from Linux to QNX. Then, we should be able to figure out what the problem is
It would be nice if somebody could point us to the PPP for QNX source code.
The pppd source code for QNX is part of the networking code and you will need a source code license to receive a copy of
 it.
I've had QNX pppd communicating to Linux pppd over a serial link, so there shouldn't be a problem as long as all the
options are setup properly.
