Forum Topic - Help learning to use the packet filtering tools:
I'm looking for a good tutorial for getting started with the packet filtering/network sniffing tools.
From what I can see I want to use either pf or bpf.
I want to be able to open packets with address for machine other than mine, so whichever is best for that.
Re: Help learning to use the packet filtering tools
To see packets sent to other addresses you will need to use BPF as that is the only way you can put the interface in
promiscuous mode. Here's some example code that I found on a quick search:
https://gist.github.com/manuelvonthron-opalrt/8559997
Note that libpcap uses BPF so if you find it easier to program for that then it is an alternative.
I've looked into libpcap, but I'm not sure how to get it to work for QNX, since I'm using a windows host.
I've read that it's part of QNX's standard libraries so I tried just importing it, but it can't find the function
definitions, and I can't figure out where I would get them.
See the PCAP documentation on TCPDUMP page:
http://www.tcpdump.org/pcap.html
To repeat my previous question: where is the actual libpcap.a (or equivalent) file in the QNX directory structure?
I found lots of guides on programming with libpcap, but none of them mean anything if I can't access the functions
declared in the header.
I found the header file and Momentics sees it fine, but when I tell it to include the libpcap.a file I've found (in
target/qnx6/.../usr/lib) it does not give a file not found error (meaning it SEES the library), but doesn't load the
function definitions (meaning it is the WRONG library), resulting in an 'undefined reference' error.
libpcap.a and libpcapS.a are in the SDP in the target/qnx6/<CPU>/usr/lib directory:
E.g on my Linux install of 6.6.0 in /opt/qnx660:
$ find /opt/qnx660/target/qnx6 -name 'libpcap*'
/opt/qnx660/target/qnx6/x86/usr/lib/libpcap.a
/opt/qnx660/target/qnx6/x86/usr/lib/libpcapS.a
/opt/qnx660/target/qnx6/armle-v7/usr/lib/libpcap.a
/opt/qnx660/target/qnx6/armle-v7/usr/lib/libpcapS.a
