Forum Topic - How to Fix the Source IP used in DNS Request sent from system.:
We were developing an application which requires DNS Resolution for certain configured URIs.
Now i understand that this can be done by using APIs gethostbyname or getaddrinfo.
However we have an additional problem to handle. The DNS request sent to the DNS server should use a fixed known Source
IP address in the packets sent towards DNS Server. Is it possible to force/specify DNS Service to use a fixed Source IP?
We have multiple logical IP addresses configured on an interface. We just want that DNS resolution should somehow be
carried out using 1 specific Source IP address in the pkts sent towards DNS Server.
BR
Sajal
Re: How to Fix the Source IP used in DNS Request sent from system.
Hi Sajal,
The DNS request will be sent to the servers specified in /etc/resolv.conf and the source address used will be the one
that best routes to that address. As there cannot be multiple addresses in the same subnet, one address will always be
chosen to access a particular DNS server.
Can you explain in a bit more detail the issue that you are facing?
Nick.
Hi Nick,
Thanks for your Reply.
It seems in QNX we can configure multiple logical IP Addresses in Same
Subnet on a particular ethernet interface.
Now since this is not blocked by OS, we want to somehow control which IP
Address the OS uses as Source IP while generating DNS Traffic. Is this
possible somehow?
Further needed help on another related topic:
While we configured the DNS Server IP in resolv.conf:
- We were observing that on calling "gethostbyname()" API, OS was
generating DNS Request and on not getting any reply it was making
re-attempts (6 times or so) before returning failure.
- If 2 DNS Server IPs are configured in resolv.conf then we observe that
the delay between subsequent attempts further increases with period of each
attempt also increasing incremently.
- Also we observed that when resolv.conf is in use, then on executing "arp
-a" or doing FTP, we see that OS Starts generating DNS Traffic for each IP
in ARP Table and there is a delay in output.
Queries:
- In Linux we know it is possible to control the number of attempts and
interval between each attempt by configuring parameters in resolv.conf. Is
the same also possible in QNX?
- How can we stop generation of DNS Traffic on execution of commands like
"arp -a" or ftp?
Would really appreciate if you can provide some pointers for these queries.
Thanks and Regards
Sajal
BR
Sajal
On Mon, Jan 5, 2015 at 8:30 PM, Nick Reilly <community-noreply@qnx.com>
wrote:
> Hi Sajal,
> and the source address used will be the one that best routes to that
> address will always be chosen to access a particular DNS server.
> Regards,
> Nick.
> http://community.qnx.com/sf/go/post112822
> To cancel your subscription to this discussion, please e-mail
> general-networking-unsubscribe@community.qnx.com
Attachment: HTML sf-attachment-mime28291 2.91 KB
For arp, pass the -n switch:
# arp -an
I don't see any dns activity with ftp if numeric addresses are used.
If a hostname is used, dns is required to resolve it to a numeric
address.
You can change timeout parameters in resolv.conf:
options timeout:x attempts:y
Or from code:
# include <resolv.h>
struct  __res_state * res = __res_get_state();
res->retrans = x;
res->retry = y;
getaddrinfo(...);
On Wed, Jan 07, 2015 at 01:48:14PM +0530, Sajal Malhotra wrote:
> Hi Nick,
> It seems in QNX we can configure multiple logical IP Addresses in Same Subnet
> Address the OS uses as Source IP while generating DNS Traffic. Is this possible
> somehow?
> - We were observing that on calling "gethostbyname()" API, OS was generating
> DNS Request and on not getting any reply it was making re-attempts (6 times or
> - If 2 DNS Server IPs are configured in resolv.conf then we observe that the
> delay between subsequent attempts further increases with period of each attempt
> - Also we observed that when resolv.conf is in use, then on executing "arp -a"
> or doing FTP, we see that OS Starts generating DNS Traffic for each IP in ARP
> Queries:
> interval between each attempt by configuring parameters in resolv.conf. Is the
> - How can we stop generation of DNS Traffic on execution of commands like "arp
> -a" or ftp?
> Thanks and Regards
> Sajal
> BR
> Sajal
> On Mon, Jan 5, 2015 at 8:30 PM, Nick Reilly <community-noreply@qnx.com> wrote:
>     Hi Sajal,
>     Regards,
>     Nick.
>     _______________________________________________
>     General
> # arp -an
> address.
> Or from code:
> res->retrans = x;
> res->retry = y;
res_ninit(res);
> getaddrinfo(...);
Hi Sean,
Thanks for your help. Here are my findings after trying your suggestions:
- The arp -an option worked fine. Thankyou for the same :)
- timeout params in resolv.conf did not work(I have attached the
resolv.conf we used).
- However changing "res->retrans" and "res->retry" and res_init() *Did work
fine*. (Please Note: res_ninit does not seem to be supported on our version
of QNX OS (v6.3.0). Was getting compilation errors.)
- Also regarding dns activity in FTP and Telnet, we do see still see the
same. I have attached the wireshark logs of the time when we just executed
a simple ftp command with numeric IP Addresses (ftp 192.168.255.131).  The
Telnet and FTP commands get stuck till these pkt transmissions are
completed. (Please use "dns" filter in pcap file to see the query pkts that
are generated by kernel)
The moment we remove DNS Server IPs from resolv.conf, the issue is not
seen. Can you put some light on this as well.
PS: We are using QNX v6.3.0.
BR
Sajal
On Wed, Jan 7, 2015 at 8:16 PM, Sean Boudreau <community-noreply@qnx.com>
> > # arp -an
> > address.
> > Or from code:
> > res->retrans = x;
> > res->retry = y;
> res_ninit(res);
> > getaddrinfo(...);
> http://community.qnx.com/sf/go/post112854
Attachment: Text addr_arpa.pcap 30.84 KB Text Resolv.conf.txt 72 bytes HTML sf-attachment-mime28514 3.49 KB
Hi Nick, Sean,
Any Inputs you could give on my queries in last post.
BR
Sajal
On Mon, Jan 19, 2015 at 1:32 PM, Sajal Malhotra <sajalmalhotra@gmail.com>
wrote:
> Hi Sean,
> work fine*. (Please Note: res_ninit does not seem to be supported on our
> version of QNX OS (v6.3.0). Was getting compilation errors.)
> BR
> Sajal
>> > # arp -an
>> > address.
>> > Or from code:
>> > res->retrans = x;
>> > res->retry = y;
>> res_ninit(res);
>> > getaddrinfo(...);
>> General
Attachment: HTML sf-attachment-mime28711 4.12 KB
6.3.0 is really really old. I'd suggest that if you really need this to work you purchase a support contract and come in
 through that way. Otherwise try 6.5.0 SP1 or 6.6.0.
