Forum Topic - Manage socket during cable disconnection:
Hi
I have to manage the case of the cable disconnection. Then it occured the "send" function work a little time (buffer
filling) then the "send" function block during a very long time out (many minutes).
Is there a way to detect this case (cable disconnection) ?
Is there a way to manage this timeout ?
Thank
Olivier
Re: Manage socket during cable disconnection
If you just want to look at the link state of the node then it is reported by ifconfig and can be fetched
programatically by doing a SIOCGIFDATA and looking at the ifdata.ifdr_data.ifi_link_state
N.B. This only reports the node link state, if the path between the two TCP endpoints is broken somewhere in the middle
then the node link state may still be up.
I think what you are actually looking for is the TCP Keepalive mechanism, please see our documentation and example code
for it:
http://www.qnx.com/developers/docs/660/index.jsp?topic=%2Fcom.qnx.doc.neutrino.lib_ref%2Ftopic%2Fg%2Fgetsockopt.html&
anchor=getsockopt__Keepalive
Thank for your reply
I ll try this
Olivier
