Forum Topic - asix usb ethernet dongle problem:
Hi all,
I'm trying to connect to o (armle) target.
the target starts a script from usb on boot.
I can load the devn-asix driver , and that fires up the usb adaptor (lights on)
This is what i try :
io-pkt-v4-hc -d /fs/U0/devn-asix.so lan=2
ifconfig en2 192.168.6.2
i can ping 192.168.6.2 , but can't ping to the other end of the ethernet..
in syslog :
Jan 01 00:00:27    5    14     0 tcpip starting
Jan 01 00:00:28    3    14     0 Unable to attach to pci server: No such file or directory
Jan 01 00:00:28    3    14     0 Using pseudo random generator.  See "random" option
Jan 01 00:00:28    5    14     0 initializing IPsec... done
Jan 01 00:00:28    5    14     0 IPsec: Initialized Security Association Processing.
Jan 01 00:00:30    5    14     0 en2
Jan 01 00:00:30    2    14     0 ax_initialize:  unable to enqueue rcv buffer 13
Any help is welcome..
Re: asix usb ethernet dongle problem
If you are starting io-pkt in a script and then running ifconfig
immediately after, that could be your problem. You should have a delay
after starting the driver and running ifconfig to allow the driver to
initialize the hardware.
On 2014/1/21, 6:05 PM, "a l" <community-noreply@qnx.com> wrote:
>Hi all,
>(lights on)
>in syslog :
>file or directory
>"random" option
>Processing.
>buffer 13
>General
>http://community.qnx.com/sf/go/post108074
>general-networking-unsubscribe@community.qnx.com
Thanks...
I did put a sleep between it...
After running ifconfig it also lists the interface with the configured ip address.
Also disabling packet filtering did not help.
After network setup i can ping to the configured target ip address..but nothing to host..
Please can you post the output from ³usb -v² so that I can see which
version of the Asix chip you have.
On 2014/1/22, 9:01 AM, "a l" <community-noreply@qnx.com> wrote:
>Thanks...
>address.
>nothing to host..
>General
>http://community.qnx.com/sf/go/post108083
USB 0 (dm816x) v1.10, v1.01 DDK, v1.01 HCD
    Control, Interrupt, Bulk(SG), Isoch(Stream), High speed
Device Address             : 1
Upstream Host Controller   : 0
Upstream Device Address    : 0
Upstream Port              : 0
Upstream Port Speed        : High
Vendor                     : 0x04b8
Product                    : 0x090a
Device Release             : r0.90
Class                      : 0x09 (Hub)
Subclass                   : 0x00
Protocol                   : 0x01
Max PacketSize0            : 64
Hub Number Ports           : 2
Hub Characteristics        : 0x0020 (Ganged power, Global over-current)
Hub Power On->Good         : 0 ms
Hub Power Requirements     : 100 mA
Configurations             : 1
  Configuration            : 1
    Attributes             : 0xe0 (Self-powered, Remote-wakeup)
    Max Power              : 100 mA
Device Address             : 2
Upstream Device Address    : 1
Upstream Port              : 2
Vendor                     : 0x2101 (Action Star)
Product                    : 0x8500 (USB2.0 Hub)
Device Release             : r1.06
Class                      : 0x09 (Hub)
Subclass                   : 0x00
Protocol                   : 0x02
Hub Number Ports           : 5
Hub Characteristics        : 0x00e4 (Ganged power, Compound, Global over-current)
Hub Power On->Good         : 100 ms
Configurations             : 1
  Configuration            : 1
    Max Power              : 100 mA
Device Address             : 3
Upstream Device Address    : 2
Upstream Port              : 1
Product                    : 0x8501 (USB HID)
Device Release             : r6.05
Class                      : 0x00 (Independent per interface)
Configurations             : 1
  Configuration            : 1
    Attributes             : 0xa0 (Bus-powered, Remote-wakeup)
    Max Power              : 20 mA
Device Address             : 4
Upstream Port              : 2
Vendor                     : 0x1307 (USBest Technology)
Product                    : 0x0163 (USB Mass Storage Device)
Device Release             : r1.00
Configurations             : 1
  Configuration            : 1
    Attributes             : 0x80 (Bus-powered)
    Max Power              : 80 mA
Device Address             : 5
Upstream Port              : 3
Vendor                     : 0x2001 (D-Link Corporation)
Product                    : 0x3c05 (DUB-E100)
Device Release             : r0.01
Class                      : 0xff (Vendor-specific)
Subclass                   : 0xff
Protocol                   : 0x00
Configurations             : 1
  Configuration            : 1 (0)
    Max Power              : 250 mA
USB 1 (dm816x) v1.10, v1.01 DDK, v1.01 HCD
    Control, Interrupt, Bulk, Isoch(Stream), High speed
We have ported the Asix driver to a native io-pkt driver, so will you
please run the attached driver and see if it works for you.
>Device Address             : 1
>Upstream Port              : 0
>Vendor                     : 0x04b8
>Product                    : 0x090a
>Class                      : 0x09 (Hub)
>Subclass                   : 0x00
>Protocol                   : 0x01
>Configurations             : 1
>  Configuration            : 1
>    Max Power              : 100 mA
>Device Address             : 2
>Upstream Port              : 2
>Class                      : 0x09 (Hub)
>Subclass                   : 0x00
>Protocol                   : 0x02
>over-current)
>Configurations             : 1
>  Configuration            : 1
>    Max Power              : 100 mA
>Device Address             : 3
>Upstream Port              : 1
>Configurations             : 1
>  Configuration            : 1
>    Max Power              : 20 mA
>Device Address             : 4
>Upstream Port              : 2
>Configurations             : 1
>  Configuration            : 1
>    Max Power              : 80 mA
>Device Address             : 5
>Upstream Port              : 3
>Subclass                   : 0xff
>Protocol                   : 0x00
>Configurations             : 1
>    Max Power              : 250...
Attachment: Text devnp-asix.so.armv7 76.59 KB
Thanks for your help , really appreciated !!
With the new driver.. (mount -Tio-pkt /fs/U0/devnp-asix.so)
- The dongle start..led turn on (same as old driver)
- No /dev/io-net is created
syslog:
Jan 01 00:00:22    5    10     0 ax_detect: attached [bus 0, dev 5]
Jan 01 00:00:22    5    14     0 ax0
Jan 01 00:00:25    5    10     0 ax_detect: attached AX interfaces 0
Jan 01 00:00:25    5    10     0 ax_detect: found 1 device
Jan 01 00:00:56    2    10     0 error 2
Jan 01 00:00:56    2    10     0 ax_initialize:  unable to enqueue rcv buffer 13
Yes, io-pkt drivers don¹t create a /dev/io-net.
Has this dongle worked before? The fact that both drivers indicate the
same problem, seems to indicate a hardware problem.
>syslog:
>buffer 13
>General
>http://community.qnx.com/sf/go/post108090
The dongle currently works on the vm-ware x86 image..and on a other target (also arm-le)
I tried driver from that target , same result.
Difference is that the other target is prepared for this dongle (driver loaded via enum..ect).
Can there be something on the target that causes this error..?
it's giving me a lot of trouble..
Also can't load devc-serusb  (can't create /dev/serusb error)..so no comm at the moment..other that the boot script from
 usb.
It sounds to me as though you have a USB problem with that target, rather
than a network driver problem. We have a lot of those DLink dongles here
that we use all the time, so I know that the driver works.
I cannot help you with USB problems, so maybe you should post this
question on another conference.
>at the moment..other that the boot script from usb.
>Thanks
>General
>http://community.qnx.com/sf/go/post108094
Turned out the target had some custom enum system..
That system prevented my manually loaded driver from working..
I changed the vid&pid in the system img (hexedit) so it loads my dongle driver with the custom enum system..and it works
 like a charm.
Thanks for your help !!
