Forum Topic - GPIO Crownbay:
GPIO Crownbay
Has anybody used the GPIO in Crownbay Intel Topcliff?
Regards
Re: GPIO Crownbay
Hi again !
I'm trying to develop a simple driver for managing GPIO in Intel Topcliff. I can attach PCI GPIO subsystem, and it
suppose that now I can map mem address...so I can read and write. The first approach is to read the input. I have put a
pin to ground, so it's suppose I should read FFE, but I always read 0xFFF. It's like there was someting wrong in the
memory mapping or so.
Once I attach I have this information
Aperture 1: Base 0xd0157000 Length 64 bytes Type MEM
So I mmap_device_memory to a volatile uint32_t pointer. At this point If I do:
data = *((volatile uint32_t*)((uintptr_t)memMap+GPIO_PORT_INPUT));
I should get 0xffe, but got 0xfff
Did I miss something?
The port mode it's in input mode, irq disabled..
Thanks for your help !
Re: GPIO Crownbay
Hi Iván, did you ever get the GPIO working?
Re: GPIO Crownbay
Yes, I don't have the source code with me but I could use INPUT and OUTPUT. If you are interested I can take a look at
the code to tell you how I did it
Best Regards !
Re: GPIO Crownbay
Hi Ivan,
We are using the Kontron COMe mTT10 which has the EG20T topcliff PCH (not sure what board you were using) and uses the
EG20T GPIO to provide 4 off GPI and 4 off GPO which, to add confusion, share pins with an SD card interface.  Anything
you have to help would be appreciated, known working code for the EG20T GPIO gets me one step closer to working GPIO on
the COMe mTT10 ...
Thanks!
