Forum Topic - io-pkt-v4-hc and multiple network interfaces: (5 Items)
Greetings QNX community
Our QNX 6.5.0 SP1 project requires two Ethernet connections, both using USB Ethernet style adapters. Although the
adapters are of the same nature, they are different mfg/part numbers and hence use different QNX drivers.
Both devices are successfully enumerated by the HC (as listed by usb tool)  and I can get each connection to work
separately using io-pkt-v4-hc/ifconfig harness:
io-pkt-v4-hc -vvvv -d<driver> -ptcpip
ifconfig en0 <ip> netmask <mask>
The problem starts when I'm trying to get both interfaces up at the same time:
io-pkt-v4-hc -vvvv -d<driver1> -ptcpip   <-- Success, /dev/io-net/en0  appears
io-pkt-v4-hc -vvvv -d<driver2> -ptcpip   <-- Success, but en1 doesn't appear anywhere as i was expecting. No errors
reported though.
Then I read carefully again through io-pkt-v4-hc documentation and found something called "instance" in there. So I
tried specifying different instance numbers for each adapter:
io-pkt-v4-hc -i 1 -vvvv -d<driver1> -ptcpip   <-- Success, /dev/io-net1/en0  appears
io-pkt-v4-hc -i 2 -vvvv -d<driver2> -ptcpip   <-- Success, /dev/io-net2/en0  appears
At this point I'm very confused, this is clearly is not what I want to achieve. This seems to be creating separate
stacks and further I don't quite see how to use ifconfig in this setup as both interfaces are registered as "en0".
I also tried to play with "enmap" parameter but this one seems to be ignored completely.
All I want is just to get my two network interfaces under /dev/io-net/ as
/dev/io-net/en0
/dev/io-net/en1
So that I can configure them as usual with
ifconfig en0 <ip1> netmask <mask1>
ifconfig en1 <ip2> netmask <mask2>
Any suggestions?
Thanks.
Re: io-pkt-v4-hc and multiple network interfaces
Sounds like you simply want:
# io-pkt -d driver1 -d driver2
If you want multiple stacks you'll have do add the 'prefix' option
to target them individually with utilities.
# io-pkt -d driver1
# ifconfig
# io-pkt -d driver2 -ptcpip prefix=/alt
# SOCK=/alt ifconfig
This is all be documented in the io-pkt docs.
reported though.
> /dev/io-net/en0
> /dev/io-net/en1
> Any suggestions?
> Thanks.
> http://community.qnx.com/sf/go/post98877
> To cancel your subscription to this discussion, please e-mail general-networking-unsubscribe@community.qnx.com
Thanks Sean
Interesting, I just checked again io-pkt docs at http://www.qnx.com/developers/docs/6.4.0/neutrino/utilities/i/io-pkt.
html and seems can't find any mention you can load more than one driver at a time.
Just to confirm, are you saying I can simply do:
io-pkt-v4-hc -vvvv -d<driver1> -d<driver2> -ptcpip
ifconfig en0 ...
ifconfig en1 ...
Is that correct?
On Tue, Jan 29, 2013 at 04:06:37PM -0500, Oleg V wrote:
> Thanks Sean
In first message you mentioned 6.5 sp1.  Docs are here:
http://www.qnx.com/developers/docs/6.5.0_sp1/index.jsp?topic=%2Fcom.qnx.doc.neutrino_utilities%2Fi%2Fio-pkt.html
> ifconfig en0 ...
> ifconfig en1 ...
> Is that correct?
Right.
Thanks Sean! I'll give it a try in the morning.
