Forum Topic - Network problem: (3 Items)
Network problem
Dear all
We have QNX 6.4.1 running on a customized board based on PPC440ep processor, using customized version of AMCC PPC440 EP/
GR BSP. Board has two ethernet interfaces on different subnet .
Rarely we have problem with ethernet. Board not detected by pinging it through PC (ping fails), but PC can detected
through board using ping command.
Both PC and board are connected to one switch.
Is there any idea about this problem?
Re: Network problem
What is the output of nicinfo when this happens? Are there any error
messages in sloginfo? We will also need the output from "ifconfig".
On 2012-08-28 6:01 AM, "antony Lewis" <community-noreply@qnx.com> wrote:
>Dear all
>processor, using customized version of AMCC PPC440 EP/GR BSP. Board has
>through PC (ping fails), but PC can detected through board using ping
>command.
>Thanks
>General
>http://community.qnx.com/sf/go/post95187
>general-networking-unsubscribe@community.qnx.com
Re: Network problem
Dear Hugh
Thanks for your response.
Because problem occurs rarely, I put the board under test, as soon as it fails, I'll report the sloginfo messages.
following is ifconfig output.
# ifconfig
en0: flags=80008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 00:65:43:21:22:60
        media: Ethernet 100baseTX full-duplex
        status: active
        inet 192.168.100.226 netmask 0xffffff00 broadcast 192.168.100.255
en1: flags=80008943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST,SHIM> mtu 1500
        address: 00:65:43:21:22:61
        media: Ethernet none full-duplex
        status: active
        inet 192.168.101.226 netmask 0xffffff00 broadcast 192.168.101.255
Regards
