Forum Topic - QNET and libsocket.so: (3 Items)
Hi!
I found strange issue with Qnet over IP and I think this thing must be shown in documentation or fixed in code.
If in your target FS not present libsocket.so (not libsocket.so.2 but without .2) than Qnet over IP mount npm-qnet-
l4_lite.so but Qnet doesn't work.
So I had libsocket.so.2 but no libsocket.so in my target FS and all application which uses tcp/ip sockets work fine
except Qnet over IP. So Qnet need exactly libsocket.so (as for example symbolic link).
I found no any word about this issue in current documentation.
Thanks!
AG
As result of discussion in http://community.qnx.com/sf/discussion/do/listPosts/projects.core_os/discussion.newcode.
topc1187
RE: QNET and libsocket.so
What type of CPU architecture was this on?  I was trying it on my x86 box
and couldn't seem to reproduce it...
Does sloginfo report anything interesting in the failed case?
	Robert.
From: Andrew Golovnia [mailto:andrew_golovnia@ukr.net]
Sent: Monday, March 17, 2008 1:53 PM
To: general-networking
Subject: QNET and libsocket.so
Hi!
without .2) than Qnet over IP mount npm-qnet-l4_lite.so but Qnet doesn't
work.
application which uses tcp/ip sockets work fine except Qnet over IP. So Qnet
Thanks!
AG
ion.newcode.topc1187
General
http://community.qnx.com/sf/go/post5880
Re: RE: QNET and libsocket.so
Hi!
I'm running my tests on a xScale PXA255 with QNX 6.3.2 and io-net base network stack.
# pidin info
CPU:ARM Release:6.3.2  FreeMem:15Mb/64Mb BootTime:Jan 01 00:00:00 UTC 1970
Processor1: 1761946886 pxa250 399MHz
# pidin arg
     pid Arguments
       1 procnto
       2 slogger
   69641 io-net -dsmc9000 ioport=0x04000300,speed=10,duplex=1,irq=130,variant=generic,width=32 -ptcpip
   81931 pipe
  155661 inetd
  356413 fs-cifs //AG /HOST temp
  438331 pidin arg
# cat /etc/hosts
192.168.X.Y2 ag.pc.net.intra ag
192.168.X.Y9 dim.c3.net.intra dim
192.168.X.Y8 pam.c3.net.intra pam
192.168.X.Y9 dem.c3.net.intra dem
# setconf _CS_DOMAIN "c3.net.intra"
# setconf _CS_HOSTNAME "dim"
# sloginfo
Mar 19 10:37:26    5     8     0 Attached /dev/io-graphics/crt00, id = 3
# ls -l /lib/libsocket*
-rwxrwxrwx  1 root      0            160709 May 05  2004 /lib/libsocket.so.2
!!!! Now I'll mount QNET without libsocket.so... !!!!
# mount -Tio-net -obind=ip,resolve=dns /H*/npm-qnet.so
# ls /net
# ls /net/dim
ls: No route to host (/net/dim)
# ls /net/pam
ls: No route to host (/net/pam)
# sloginfo
Mar 19 10:41:51    7    15     0 npm-qnet(L4): qnet_birth(): qnet_init() - calling
Mar 19 10:41:51    7    15     0 npm-qnet(L4): ip_ionet_rx_ctrl(): _IO_NET_MSG_DL_ADVERT: new interface: ip0: index 0
cell 1 endpt 0 iface 2
Mar 19 10:41:51    7    15     0 npm-qnet(L4): ip_ionet_rx_ctrl(): _IO_NET_MSG_ADDR_ADD: no existing interface for
ND_LOCAL_NODE
Mar 19 10:41:51    7    15     0 npm-qnet(L4): ip_ionet_rx_ctrl(): _IO_NET_MSG_ADDR_ADD: ndb_query_add_name(dim.c3.net.
intra) returned 309
Mar 19 10:41:51    7    15     0 npm-qnet(L4): qnet_birth(): qnet_init() - complete: 0
That's it. ;-)
It looks like npm-qnet.so tried to mount libsocket.so to get gethostbyname() from there... but...
AG
> 	Robert.
> Hi!
> work.
> Thanks!
> AG
