Forum Topic - Problem with sockets: (3 Items)
I'm trying to use a server socket in a process, the code compiles without errors or warnings, however when I run it I
get:
ESRCH No such process
This is after creating the socket:
errno = EOK;
intSocket = socket( AF_INET, SOCK_STREAM, 0 );
intErr = errno;
printf( "ERROR = %s\n", strerror(intErr) );
According to the hellp http://www.qnx.com/developers/docs/6.3.0SP3/neutrino/lib_ref/s/socket.html
This isn't an error listed for this routine.  What do I need to do to resolve this problem?
I've checked /bin, libsocket.so, libsocket.so.2, npm-tcpip-v4.so and npm_tcpip.so are all present.
Thank you
Re: Problem with sockets
What is intSocket?  You shouldn't look at errno
unless the return from socket() is -1.  If it's
-1 make sure 'io-net -ptcpip ...' is running.
get:
> errno = EOK;
> intErr = errno;
> Thank you
> http://community.qnx.com/sf/go/post91702
intSocket is just defined as:
int intSocket
The error display code is just they're because I know they're is a problem and I wanted to display it.
I've moved on a little since the initial post, I've now edit /etc/services and added an entry
http  80/tcp
Having done this the error returned is now 243, Protocol not configured or not supported
So I'm thinking that something more is missing from our build.
