Forum Topic - How an application running on Windows, uses the serial port on the QNX target?:
Consider a QNX target having a serial port and a PC(using windows) which is connected to QNX target using TCP/IP or UDP.
How can a program working on windows control the serial port on the QNX target? Is this related to virtual ports on
windows. What should I do?
Re: How an application running on Windows, uses the serial port on the QNX target?
As I did recently,
i use twisted RS232 cable.
On windows side, I use software "Seriall port monitor".
On QNX side, I wrote code to open serial port and to write data over it.
