Trouble installing Samba 6.5.8
04/28/2011 9:20 AM
post85290
I'm trying to install Samba 6.5.8 on a QNX box running version 6.5.0 and is's an x86 system. I've been able to get a
partial build but after doing some extra work. In the process of the install I've had to manually install pthreads, cups
, libmcrpt, and libiconv packages. Now the samba server will run but cannot be connected to. Turning on some debug and
checking the log files I got the following messages:
[2011/04/27 13:03:33.141910, 0] printing/pcap.c:178(pcap_cache_reload)
Unable to open printcap file /etc/printcap for read!
[2011/04/27 13:03:35.573538, 1] lib/account_pol.c:325(account_policy_get)
account_policy_get: tdb_fetch_uint32 failed for type 1 (min password length), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 2 (password history), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 3 (user must logon to change password), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 4 (maximum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 5 (minimum password age), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 6 (lockout duration), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 7 (reset count minutes), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 8 (bad lockout attempt), returning 0
[2011/04/27 13:03:35.574538, 1] lib/account_pol.c:325(account_policy_get)
account_policy_get: tdb_fetch_uint32 failed for type 9 (disconnect time), returning 0
account_policy_get: tdb_fetch_uint32 failed for type 10 (refuse machine password change), returning 0
[2011/04/27 13:03:45.312048, 0] lib/util_sock.c:844(open_socket_in)
open_socket_in(): socket() call failed: Address family not supported by protocol family
[2011/04/27 13:03:45.361041, 0] smbd/server.c:500(smbd_open_one_socket)
smbd_open_once_socket: open_socket_in: Address family not supported by protocol family
[2011/04/27 13:03:45.361041, 0] lib/util_sock.c:844(open_socket_in)
I'm not worried about the pcap messages, the socket issues is really the big issue. Has anyone else run into this
problem and have a fix?
Also during the configuration an error involving -lpthreads was thrown. Has this happed to anyone else and is there a
fix?
Re: Trouble installing Samba 6.5.8
04/28/2011 10:11 AM
post85295
Make sure io-pkt is running.
On Thu, Apr 28, 2011 at 09:20:22AM -0400, Dan Fenton wrote:
> and is's an x86 system. I've been able to get a partial build but after
> manually install pthreads, cups, libmcrpt, and libiconv packages. Now
> debug and checking the log files I got the following messages:
> time), returning 0
> by protocol family
> protocol family
> by protocol family
> protocol family
> big issue. Has anyone else run into this problem and have a fix?
> Has this happed to anyone else and is there a fix?
> http://community.qnx.com/sf/go/post85290
04/28/2011 2:56 PM
post85304
Wound up just starting form the beginning and re-configuring, re-compiling, re-making, and re-make install and got it to
run and allow users to connect. Now my problem is when more than one user connects at a time Samba seems to lock up.
Checking the log files for the machines that were connected gave the following debug message:
smbd/connection.c:claim_connection(208)
claim_connection: tdb_store failed with error Corrupt database.
do i need separate lock files for each share?
can anyone shed some light on this? And I should add again that there was a problem with -lpthreads so in the make
process the Makefile was edited to not use -lpthreads
04/28/2011 3:32 PM
post85305
> re-compiling, re-making, and re-make install and got it to run and allow
> a time Samba seems to lock up. Checking the log files for the machines
Try commenting out 'HAVE_MMAP' in your config.h after
configure but before make.
> was a problem with -lpthreads so in the make process the Makefile was
That shouldn't be a problem.
04/28/2011 3:39 PM
post85306
Disregard my last post. I'm still having the same issue as stated in my original post.
-Dan
