tftpd returns "port unreachable" error
03/15/2011 5:35 AM
post83983
I have a requirement to start "tftpd" service in mpc85xx target card.
1. I edited the "inetd.conf" and "services" files as follows and then restarted the card.
/etc/inetd.conf has the configuration:
tftp dgram udp nowait root /proc/boot/tftpd in.tftpd -s /software/dir
/etc/services has the configuration
tftp 69/udp
tftpd 69/udp
2. At startup "netstat -a | grep tftp" gives:
udp 0 0 *.tftp *.*
3. From the client card when I tftp to the server card and tried to get a file that is placed in the tftp root
directory(the path specified in the inetd.conf) of the server, I get "Transfer timed out".
4. After this the "netstat -a | grep tftp" command in the server card does not display anything.
5. tcpdump on the server card shows, the following error: "UDP port tftp unreachable".
6. tcpdump on the client card also shows, the following error: "UDP port tftp unreachable".
How can we verify that tftpd is running?
Are there any other configurations to run tftpd properly?
