Forum Topic - QNX 6.4.1 dual core:
QNX 6.4.1 dual core
 Hello All ,
 When we install the qnx 6.4.1 os on an intel dual core processor ,
 would it by default use only one cpu or would it configure to take
 advantage of both CPU's . I have done just a regular install with type
 79 file system.
The pidin in  listing relevant o/p says
Processor1: 66222 Pentium III Stepping 10 2825MHz FPU
does that mean it is aware of only one cpu
thanks
subra
RE: QNX 6.4.1 dual core
By default the installation process install the single core version. To install the smp version cp /boot/fs/qnxsmpbase.
ifs /.boot
> -----Message d'origine-----
> De : Subra arya [mailto:community-noreply@qnx.com]
> Envoyé : 24 janvier 2011 16:26
> À : general-networking
> Objet : QNX 6.4.1 dual core
>  Hello All ,
>  When we install the qnx 6.4.1 os on an intel dual core processor ,  would it by
> default use only one cpu or would it configure to take  advantage of both
>  79 file system.
> thanks
> subra
> http://community.qnx.com/sf/go/post82595
Re: RE: QNX 6.4.1 dual core
I  did try that too ie copying /boot/fs/qnxbasesmp.if    /.boot .
My pidin in  out put remains same .
I know i am running a dual core .
So just by looking at pidin in output i am not able to say if  my os is taking advantage of all the cpu cores  or not .
Any other info is helpful .
thanks
subra
RE: RE: QNX 6.4.1 dual core
> Envoyé : 25 janvier 2011 08:40
> Objet : Re: RE: QNX 6.4.1 dual core
I assume you rebooted after you did that?  Maybe the second core is disable in the BIOS?
> thanks
> subra
> http://community.qnx.com/sf/go/post82615
Re: QNX 6.4.1 dual core
When copying .boot files like that remember to run sync before you
reboot, especially on the qnx6 fs
>> thanks
>> subra
>> General
> http://community.qnx.com/sf/go/post82627
cburgess@qnx.com
Re: RE: RE: QNX 6.4.1 dual core
It does work .
Thank you
