Forum Topic - How to check route information?: (5 Items)
I tried "route print" to check the gateway address but failed. It showed that "botched keyword: print". So how can I
check the gateway and how to use route command in qnx?
I'm using qnx 6.3.2.
Thanks.
Re: How to check route information?
On Mon, Sep 20, 2010 at 05:15:38PM -0400, Yuan Sun wrote:
# route show
# netstat -r[n]
Thank you.
I have another question. When I checked the gateway, the one I concerned about showed: 00:40:05:a1:66:fb.
What does this mean?
In fact, I was trying to ping gateway address to check my machine's network problem. It's connected in a local network
and could work normally last week. But today I found I couldn't either ping it from other machines or ping others from
it. And the light on the hub was off when the cable connection had no problem.
How can I check the gateway address for ping other than the gateway mac address? Or are there any other ways to find out
 where the problem lies?
Thank you so much.
You can use
#netstat -r to check all routes in your PC.
