Forum Topic - default hostname: (6 Items)
default hostname
Default hostname is generated using the last 3 bytes of the MAC address.  Wouldn`t it be safer to use all 6 bytes given
that qnet goes offline if the hostname/domain isn`t unique?
RE: default hostname
Given that the top 3 bytes are manufacturer ID, using all six
really wouldn't make much difference unless you have the
same bottom 3 bytes from the different manufacturers which
is somewhat unlikely.
aboyd
Sent: Fri 8/6/2010 5:55 AM
To: general-networking
Subject: default hostname
General
http://community.qnx.com/sf/go/post61988
Unlikely but possible.  I`d prefer not having to worry if in 10 years from now we need to swap a computer at a customer
site.  If Murphy can bite, it will ;-)  That being said, I don`t care because it is a requirement of our design to
specify a unique name for each computer we ship.  But I`m told some people are concerned .
-----Message d'origine-----
De : Andrew Boyd [mailto:community-noreply@qnx.com]
Envoyé : 6 août 2010 12:41
À : general-networking
Objet : RE: default hostname
Given that the top 3 bytes are manufacturer ID, using all six really wouldn't make much difference unless you have the
same bottom 3 bytes from the different manufacturers which is somewhat unlikely.
aboyd
General
General
http://community.qnx.com/sf/go/post62069
You should keep in mind that qnet really has no right to be changing
the hostname.  I put that hack in there as kind of an emergency backup
to make qnet work in case people didn't correctly configure their systems
with proper hostnames.
You really shouldn't be relying on emergency backups as part of your
normal ops.  Would you drive around with no front brakes in you car, hoping
that you emergency handbrake on the rear drums would do the job?
Anyways, the odds of having two boards with the same lower 3 bytes is
right up there with me winning the lottery next week, and I've never purchased
a lottery ticket in my life  :)
aboyd
Sent: Fri 8/6/2010 10:10 AM
Subject: RE: default hostname
aboyd
General
General
General
http://community.qnx.com/sf/go/post62085
For sake of argumentation:
I have never seen anywhere in the documentation that giving a hostname other the one generated automatically is a
requirement for reliability.  Funny, I find that by using three bytes only, qnet is relying on emergency handbrake.
Envoyé : 6 août 2010 13:23
You should keep in mind that qnet really has no right to be changing the hostname.  I put that hack in there as kind of
an emergency backup to make qnet work in case people didn't correctly configure their systems with proper hostnames.
You really shouldn't be relying on emergency backups as part of your normal ops.  Would you drive around with no front
brakes in you car, hoping that you emergency handbrake on the rear drums would do the job?
Anyways, the odds of having two boards with the same lower 3 bytes is right up there with me winning the lottery next
week, and I've never purchased a lottery ticket in my life  :)
aboyd
aboyd
General
General
General
General
http://community.qnx.com/sf/go/post62092
Qnet relies on each host having a unique hostname, for database
indexing purposes.  It should be documented.  You should configure
your hosts with unique hostnames.  You should not rely upon this
hack in Qnet.
aboyd
Sent: Fri 8/6/2010 10:36 AM
aboyd
aboyd
General
General
General
General
General
http://community.qnx.com/sf/go/post62096
