Re: ftp ls command does not return list of files
04/07/2010 2:23 PM
post51295
On Wed, Apr 07, 2010 at 02:17:16PM -0400, Durwin De La Rue wrote:
> I can ftp to the arm. Everything seems to work, I can cd, even get, and put (only after setting passive), and while
ls does return this;
> ftp> ls
> 200 PORT command successful.
> 150 Opening ASCII mode data connection for '/bin/ls'.
> 226 Transfer complete.
> I get no list of files.
> After much searching on this issue I decided to at least get current source and build the ftpd. That in its self was
a task, but I completed it. However, after creating a new image and flashing it into the LPC3180, I found I get the
same results.
> Is there anything I missed?
- make sure you've a /bin/ls
- make sure pipe is running
- Try setting up syslogd and 'running ftpd -Dd' then
check the syslog
