mount QNET vs starting with io-pkt
04/07/2010 9:14 AM
post51266
I have a system with 4 units running QNET. What I would like to do is use a resolver file, so that specific units can
only be seen by other specific units. I.e 4 units are really 2 partner sets, and I'd like only partners to see each
other and not the rest of the network.
I've created a resolver file qnet_hosts (each unit has 2 nics)
# QNET Host Database
UNITNAME1 00:80:74:00:13:2c,00:80:74:00:13:2d
If I start io-pkt this way:
io-pkt-v4 -dppc885_mii channel=1,phy=1 -dppc885_mii channel=2,phy=3 -ptcpip -pqnet auto_add=0,resolve=file:/bin/
qnet_hosts
Everything works as expected.
However if i start it this way:
mount -Tio-pkt lsm-qnet.so auto_add=0,resolve=file:/bin/qnet_hosts
QNET starts, but it sees every other node on the system. I'd like to mount QNET by itself, because the file is in
another mount point not available at the time io-pkt starts.
Does mount not support the command line options or am I not entering the options properly?
Thank you for your input in advance.
