Forum Topic - TCP Connection Termination Sequence Issue:
I am trouble-shooting with WireShark a TCP termination issue between an off-board service (remote host) running a mini-
TCP stack and a QNX client running 6.4.1 with io-pkt-v4. I have attached two traces that illustrate my issue. I was
hoping a QNX expert could take a quick look and help me determine if both termination sequences are valid and help
identify (if it exists) any issue with mini-stack. The sequences are very short and boil down to 3-4 frames that need
examination.
The first trace (linux_client.pcap) shows a linux client (curl) connecting to the remote service, issuing an HTTP GET
and then dropping the connection. The sequence behaves properly using the mini-TCP stack and the connection is
successfully disconnected (see frames 4 - 11).
The second trace (qnx_client.pcap) involves the same client (curl) running under QNX and connecting to the same remote
host.  The disconnection fails and the link goes into a perpetual FIN, FIN-ACK  sequence between the client and service.
 The pertinent frames are 7- 11.
The real difference I can see between the two traces is the fact that the Linux stack shows the following sequence:
Client (192.168.1.2)                          Server (192.168.1.1)
ACK
FIN-ACK
                                                            FIN
                                                            ACK
whereas the QNX stack does the following:
FIN-ACK
                                                            the wheels fall off and we enter
                                                            and endless loop
Can someone please take pity on me and verify that QNX's connection termination sequence is legitimate and point out any
 obvious errors with the mini-TCP stack state machine. This is not my area of expertise but I hoped someone with a
little better understanding on the TCP state transitions could provide some helpful advice.
Attachment: Compressed file qnx_traces.zip 1.46 KB
Re: TCP Connection Termination Sequence Issue
Glenn,
I'm sorry, but I don't have the time to take a deep look right now. If
you need a response quickly then please go through the support channels.
I'm not sure what you mean by mini-TCP stack? Is it running on QNX? What
QNX version is this?
Without looking at the traces, it should be ok that the Client
terminates the connection with a single FIN-ACK or the ACK, FIN-ACK
sequence. Both should be legal.
What stack implementation is the Server running? Is it really an endless
loop? Or is it just that it's timing out and resending the last segment?
Then it will eventually stop...
/P
-TCP stack and a QNX client running 6.4.1 with io-pkt-v4. I have attached two traces that illustrate my issue. I was
examination.
. The pertinent frames are 7- 11.
> ACK
> FIN-ACK
>                                                              FIN
>                                                              ACK
> FIN-ACK
>                                                              and endless loop
any obvious errors with the mini-TCP stack state machine. This is not my area of expertise but I hoped someone with a
> http://community.qnx.com/sf/go/post50336
Patrick -
Thanks for at least reading the post and providing comments. I tried to keep the traces to the absolute minimum so if
your time does free up, I'd really appreciate it if you can take a quick glimpse at them.
To answer your questions:
1) The "mini-TCP" stack is written in Java and is running on a Blackberry. It is not using the regular BB network stack
but rather a small custom one that can be used (with SLIP) to communicate over a serial port between the phone and the
QNX device. I do not have access to the source code for this stack.
2) It sure seems like an endless loop. I've waited  several minutes before and it appears to keep going and going.
Perhaps I didn't wait long enough ;-)
Honestly, I'm hoping to collect enough detail to point a finger at the vendor. They claim it works fine with Linux
(which it does) so that leaves me with proving why it doesn't work with QNX's NetBSD based stack. Any ammunition you
could provide would be greatly appreciated.
Glenn
examination.
> ACK
> FIN-ACK
>                                                             FIN
>                                                             ACK
> FIN-ACK
>                                                             and endless loop
Their sending the fin without the ack flag set which we ignore.
There's no set behaviour for this but it's often a symptom
of someone trying to probe sequence numbers.  tcpdump seems to
know something's odd as it displays the sequence number of the
fin as an absolute, rather than relative value.
Hi
I need wireshark software for QNX 6.4, so can you please tell from where I can get it and How to install it on QNX 6.4
Wireshark doesn't run on QNX. What you do is use tcpdump (which runs under QNX) to capture a trace and write it to a
file that ends in "*.pcap". Transfer that file to your PC and open it with Wireshark.
I think the command I usually use is something like:
tcpdump -i en0 -s 65535 -w trace.pcap
Hope that helps.
Glenn
Thanks Glenn, I didn't realize you had already answered.
PS. snap length zero can also be used.
> under QNX) to capture a trace and write it to a file that ends in
> Hope that helps.
> Glenn
> http://community.qnx.com/sf/go/post77760
There's no Wireshark port for QNX AFAIK, but you can use tcpdump to grab
a pcap file on target. Then you can use Wireshark on another OS to read
the capture.
Hope this helps!
/P
On 10-12-08 04:40 AM, swati jaiswal wrote:
> Hi
> Thanks
> http://community.qnx.com/sf/go/post77752
