Re: QUERY : io-pkt-v4-hc on std x86 BIOS PC
03/16/2010 8:15 AM
post49582
The enumerators start the network driver. If you look in
/etc/system/enum/devices you will see a 'net' file that contains all the
network device IDs. If you run 'nicinfo', you will see that the device in
your case will be wm0. To run pdebug, all you need to do is run 'pdebug
8000'.
On 10-03-16 8:05 AM, "Arystor Limited" <community-noreply@qnx.com> wrote:
> hello:
> where is io-pkt-v4-hc started on a standard x86 BIOS PC when using QNX
> Neutrino 641? i checked /dev/ and did not find any networking device.
> here is the output from pidin.
> /etc> pidin -P io-pkt-v4-hc mem
> pid tid name prio STATE code data stack
> 114710 1 sbin/io-pkt-v4-hc 21o SIGWAITINFO 868K 1024K 8192(516K)*
> 114710 2 sbin/io-pkt-v4-hc 10o RECEIVE 868K 1024K 8192(132K)
> libc.so.3 @b0300000 468K 12K
> devnp-e1000.so @b8200000 180K 4096
> /dev/mem @40100000 (ed300000) 128K
> /dev/mem @40120000 (ed400000) 128K
> /etc> ls /net
> ls: No such file or directory (/net)
> /etc> cd rc.d
> /etc/rc.d> grep -i devnp-e1000 *
> /etc/rc.d> cd
> i need to know the networking device to be used for pdebug to debug using the
> Ethernet port.
> thank you in advance.
> have a Happy St Patrick's Day!
> Aaron
> http://community.qnx.com/sf/go/post49580
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
