Forum Topic - Does QNX support Cahnnel bonding or link aggregation ?:
Hi, I need bonding support on my NICs for redundancy. As far as I understand, QNX does not support this right now
(besides of QNET, I need it to comunicate with a Windows PC).
But I've seen that io-pkt is much more closely tracks the NetBSD stack source and drivers and utilities should port much
 easier to QNX io-pkt. So I was wondering if when the transition is ready (is there an estimated date for that ?)
perhaps support for this would be ready too ?
Thanks a lot,
Rodrigo
Re: Does QNX support Cahnnel bonding or link aggregation ?
much easier to QNX io-pkt. So I was wondering if when the transition is ready (is there an estimated date for that ?)
In the NetBSD world what you may want is called "agr", but it isn't
currently supported in io-pkt.
You may have luck with some clever "pf" rules though depending on
exactly what you're trying to do...
If you want to discuss dates I suggest you go through the support channels.
Cheers!
/P
> , QNX does not support this right now (besides of QNET, I need it to
> source and drivers and utilities should port much easier to QNX io-pkt. So I
> that ?) perhaps support for this would be ready too ?
Yes, 'agr' is what I was referring to port. Sorry, I was not clear enough.
I need to have one IP addr and that if one card fails, the other one takes over with the same IP. I need it for
redundancy.
Do you have any idea what this pf rules would look like and if it is possble to do it on QNX 6.3.2 ?
Thanks a lot,
Rodrigo
AFAIK pf is only in io-pkt. Maybe there is something else that can be
used for io-net..?
/P
