mbuf leak (related to pppd)
10/22/2009 11:53 AM
post40506
I have discovered an mbuf memory leak (recognizable by netstat -m).
Each invocation of pppd "consumes" one mbuf.
I have a small system (memory constrained) and it creates a problem for me.
Any ideas?
Thanks, Pavel Kycina
Re: mbuf leak (related to pppd)
10/23/2009 9:02 AM
post40600
I've reproduced this. I'll keep you posted...
10/24/2009 10:24 PM
post40649
> Any ideas?
Should be fixed now.
10/26/2009 7:39 AM
post40661
Thanks for good info.
As there is a message about maintenance of svn repository, would it be possible to send me built version of pppd?
Regards, PKY
> > Any ideas?
> Regards,
> -seanb
10/26/2009 8:14 AM
post40662
It's back up now. These changes are therein.
10/26/2009 8:20 AM
post40663
BTW the fix for this is in the stack, not pppd.
10/26/2009 9:50 AM
post40676
It's probably back online, but I can't authorize to it. (though I am using the same password as to other repositories...
Could you please send me corrected io-pkt-v4?
Thanks, PKY
> -seanb
10/26/2009 1:52 PM
post40706
I checked with the powers that be and it should be up again.
Try checking it out to a new location rather than updating.
10/27/2009 6:20 AM
post40742
> the same password as to other repositories...)
> Regards,
> -seanb
Thanks, I have managed to check it out.
But I have found these two problems:
First (I managed to solve):
/tmp/qnx_core_net2/lib/io-pkt/lib/socket/net/getpeereid.c
there is no header for the function in this file.
Second (stopper for me):
make -j 1 -Cx86 -fMakefile
make[3]: Entering directory `/tmp/qnx_core_net2/lib/io-pkt/lib/dns/x86'
make -j 1 -Ca -fMakefile
make[4]: Entering directory `/tmp/qnx_core_net2/lib/io-pkt/lib/dns/x86/a'
make[4]: Nothing to be done for `first'.
make[4]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/dns/x86/a'
make[3]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/dns/x86'
make[2]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/dns'
make -j 1 -Cedit -fMakefile
make[2]: Entering directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit'
make[3]: Entering directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit/x86'
make[4]: Entering directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit/x86/a'
/usr/qnx641/host/qnx6/x86/usr/bin/qcc -Vgcc_ntox86 -c -Wc,-Wall -Wc,-Wno-parentheses
-O -DNDEBUG -I. -I/tmp/qnx_core_net2/lib/io-pkt/lib/edit -I/usr/qnx641/target/qnx6/u
sr/include -DVARIANT_a -DBUILDENV_qss /tmp/qnx_core_net2/lib/io-pkt/lib/edit/r
eadline.c
In file included from /tmp/qnx_core_net2/lib/io-pkt/lib/edit/el.h:105,
from /tmp/qnx_core_net2/lib/io-pkt/lib/edit/readline.c:60:
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/map.h:59: error: expected specifier-qualifier-l
ist before 'el_func_t'
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/map.h:73: error: expected declaration specifier
s or '...' before 'el_func_t'
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/readline.c: In function 'rl_bind_key':
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/readline.c:1568: error: 'ED_INSERT' undeclared
(first use in this function)
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/readline.c:1568: error: (Each undeclared identi
fier is reported only once
/tmp/qnx_core_net2/lib/io-pkt/lib/edit/readline.c:1568: error: for each function it ap
pears in.)
cc: /usr/qnx641/host/qnx6/x86/usr/lib/gcc/i386-pc-nto-qnx6.4.0/4.3.3/cc1 error 1
make[4]: *** [readline.o] Error 1
make[4]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit/x86/a'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit/x86'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib/edit'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/tmp/qnx_core_net2/lib/io-pkt/lib'
make: *** [all] Error 2
Any idea what went wrong?
Thanks, PKY
10/27/2009 6:32 AM
post40743
The second problem was caused by not having executable permissions on makelist in that dir.
But soon after that in
/tmp/qnx_core_net2/lib/io-pkt/lib/io-pkt/crypto/dist2/openssl/ssl/ it was unable to compile bio_ssl.c, with many errors
in ssl.h
Any idea?
Thanks, PKY
> > Regards,
> > -seanb
> parentheses
> target/qnx6/u
> lib/edit/r
> eadline.c
> qualifier-l
> specifier
> undeclared
> undeclared identi
> function it ap
> pears in.)
> 1
> Thanks, PKY
10/27/2009 8:17 AM
post40760
errors in ssl.h
> Any idea?
You're probably trying to compile for arm
with an old compiler. You can:
- exclude arm
# make EXCLUDE_CPULIST="arm"
# make CPULIST="x86 ppc"
- compile that particular file for arm with -O0
# cd lib/ssl/arm && make CCOPTS=-O0 bio_ssl.o
then continue with your previous lower level make
10/27/2009 10:57 AM
post40787
Even the first time I was making it for x86 only,
make CPULIST="x86"
Now I have tried
And the result is the same: not possible to compile bio_ssl.c
My qconfig says:
QNX SDP 6.4.1
Thanks, PKY
> unable to compile bio_ssl.c, with many errors in ssl.h
> > Any idea?
> - exclude arm
> -seanb
RE: mbuf leak (related to pppd)
10/27/2009 10:58 AM
post40788
Please post the errors.
From: Pavol Kycina [mailto:community-noreply@qnx.com]
Sent: Tuesday, October 27, 2009 10:57 AM
To: general-networking
Subject: Re: mbuf leak (related to pppd)
make CPULIST="x86"
Now I have tried
My qconfig says:
QNX SDP 6.4.1
Re: RE: mbuf leak (related to pppd)
10/27/2009 11:10 AM
post40791
Attached file is the output of:
make CPULIST=x86 2>/tmp/qnx_corenet.log_err
PKY
> Thanks,
> -seanb
> make CPULIST="x86"
> Now I have tried
> My qconfig says:
> QNX SDP 6.4.1
10/27/2009 11:17 AM
post40794
You need to do a 'make CPULIST=x86 install'
from the root. I believe this should be
solved if libcrypto is built beforehand
(which it should be by default) and installed
to your stage.
-seasnb
10/28/2009 2:53 AM
post40858
Now I have compiled executable.
But at the same time I have development system in "non defined" state, as make install didn't work on stageing area, but
on real system.
I have followed:
http://community.qnx.com/sf/wiki/do/viewPage/projects.core_os/wiki/BuildTheOSSource
this is the state of my system:
# pwd
# set | grep QCONF
QCONF_OVERRIDE=/tmp/qnx_core_net2/lib/io-pkt/qconf-override.mk
# cat qconf_override.mk
USE_INSTALL_ROOT=1
INSTALL_ROOT_nto=/tmp/qnx_core_net2/lib/io-pkt/stage
# ls -D
. common dist external services sys
.. crypto dist2 lib stage utils
After make CPULIST=x86 hinstall and also make CPULIST=x86 install the stage directory is empty.
All cp commands invoked by make were copying to real system.
Any idea why?
Thanks, PKY
> to your stage.
> -seasnb
10/28/2009 9:40 AM
post40878
On Wed, Oct 28, 2009 at 02:53:07AM -0400, Pavol Kycina wrote:
> Thanks,
but on real system.
> I have followed:
> # pwd
> # set | grep QCONF
You've exported 'qconf-override.mk' but setup 'qconf_override.mk'
('-' vs '_'). This is why you shouldn't 'make install' as root
(at least the first time). :)
10/28/2009 9:49 AM
post40881
Thanks for all the assistance.
PKY
> > Thanks,
> make install didn't work on stageing area, but on real system.
> > I have followed:
> BuildTheOSSource
> > # pwd
> > # set | grep QCONF
> -seanb
10/28/2009 10:14 AM
post40889
But back to the original problem.
Now I have "home compiled" version, which leaks 1 mbuf at pppd start, and 2 mbufs when pppd terminates.
This is the information about the source code:
http://community.qnx.com/svn/repos/core_networking/trunk
ff24a42e-91d7-4d6b-b188-f2e9bd5c50fa
Rev. 2, author seanb
PKY
> PKY
> > > Thanks,
> > > I have followed:
> > BuildTheOSSource
> > > # pwd
> > > # set | grep QCONF
> > -seanb
10/28/2009 10:17 AM
post40891
You're sure you're actually running the one you
compiled? Using one at start is OK but it should
now be reaped on cleanup.
10/28/2009 10:26 AM
post40894
I have triple checked, that I am running new compiled version.
> -seanb
10/30/2009 3:07 AM
post41033
Is your inhouse version working fine?
If so, could you please send me the binary?
Thanks, PKY
> 2
> > -seanb
11/02/2009 8:30 AM
post41144
Ping?
> Thanks, PKY
> and
> > 2
> > > -seanb
11/02/2009 8:56 AM
post41146
On Mon, Nov 02, 2009 at 08:30:44AM -0500, Pavol Kycina wrote:
> Ping?
Mine appears to be working fine. It should
be the same as what's on the foundry. How
exactly are you still creating a leak?
11/02/2009 9:20 AM
post41150
I start io-pkt with these params:
io-pkt-v4 -dspeedo name=en -ptcpip -ppppmgr
And pppd:
pppd lcp-echo-failure 5 lcp-echo-interval 5 /dev/ser4 115200 nodetach defaultroute debug
There's nothing connected to ser4, so it timeouts.
I am monitoring mbuf count by netstart -m
When pppd starts, one mbuf is consumed and 2 mbufs are consumed "a second before" pppd terminates (probably doing some
cleanup before exiting).
As soon as pppd terminates, it's restarted with the same args.
It tekes approx. 1/2 minute for one "cycle".
Regards, PKY
> > Ping?
> -seanb
