Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
09/25/2009 5:02 PM
post38826
We would like to use the devn-rtl8169.so from QNX 6.4 on QNX 6.3. I tested with 6.3.2, but that version of the driver
doesn't detect the NIC.
Is it possible to port the QNX 6.4 driver to QNX 6.3.0 with no SP?
Has this already been done?
pci -v
Class = Network (Ethernet)
Vendor ID = 10ech, Realtek Semiconductor Co., Ltd.
Device ID = 8168h, RTL8111/8168B PCI Express Gigabit Ethernet controller
PCI index = 0h
Class Codes = 020000h
Revision ID = 2h
Bus number = 1
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Cache Line Size= 8h un-cacheable
PCI IO Address = dc00h length 256 enabled
PCI Mem Address = feaff000h 64bit length 4096 enabled
PCI Mem Address = fdef0000h prefetchable 64bit length 65536 enabled
Subsystem Vendor ID = 10ech
Subsystem ID = 8168h
PCI Expansion ROM = feac0000h length 131072 disabled
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 5
CPU Interrupt = 5h
Capabilities Pointer = 40h
Capability ID = 1h - Power Management
Capabilities = ffc3h - 8h
Capability ID = 5h - Message Signaled Interrupts
Capabilities = 80h - 0h
Capability ID = 10h - PCI Express
Capabilities = 201h - 8cc1h
Capability ID = 11h - MSI-X
Capabilities = 1h - 4h
Capability ID = 3h - VPD
Capabilities = 0h - 0h
RE: Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
09/28/2009 8:43 AM
post38855
You can give this one a try.
From: Mark Dornbush [mailto:community-noreply@qnx.com]
Sent: Friday, September 25, 2009 5:02 PM
To: drivers-networking
Subject: Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
tested with 6.3.2, but that version of the driver doesn't detect the
NIC.
pci -v
controller
PCI index = 0h
Revision ID = 2h
Bus number = 1
Device number = 0
Function num = 0
Status Reg = 10h
Command Reg = 7h
Latency Timer = 0h
Max Lat = 0ns
Min Gnt = 0ns
PCI Int Pin = INT A
Interrupt line = 5
CPU Interrupt = 5h
Networking Drivers
http://community.qnx.com/sf/go/post38826
Re: Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
09/28/2009 10:37 AM
post38868
Thanks for your quick reply.
I tried the new driver but didn't have any luck.
Running driver from io-net command line: io-net -drtl8169 -ptcpip
unknown symbol: _slogfd
unknown symbol: __slog_mux
unable to load dll devn-rtl8169: Unresolved symbols
Also tried using the mount command, tried:
mount -vvv -Tio-net -opci=0,vid=0x10ec /lib/dll/devn-rtl8169.so
mount -vvv -Tio-net -opci=0,vid=0x10ec,did=0x8168 /lib/dll/devn-rtl8169.so
mount -vvv -Tio-net /lib/dll/devn-rtl8169.so
Each time I get the same error.
mount: Can't mount / (type io-net)
mount: Possible reason: No such device or address
Parsed: mount from [/lib/dll/devn-rtl8169.so] mount on [NULL] type [io-net]
exec: mount_io-net -o implied -o nostat /lib/dll/devn-rtl8169.so /
Using internal mount (mount_io-net not found)
Type [io-net] Flags 0x80080000
Device [/lib/dll/devn-rtl8169.so] Directory [/]
Options []
Attached is a dump from pidin on the system. I added a 3Com Ethernet card to get some networking going.
Mark
09/28/2009 10:41 AM
post38869
OK, it was worth a try! You will have to make an official request for
this to be compiled under 6.3.0. I compiled it under 6.3.2 on my
machine, but don't have 6.3.0 installed.
Sent: Monday, September 28, 2009 10:38 AM
Subject: Re: Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
[io-net]
Options []
Mark
Networking Drivers
http://community.qnx.com/sf/go/post38868
Re: RE: Possible to port QNX 6.4 NIC driver to QNX 6.3.0?
07/13/2010 10:09 AM
post59286
Hi Hugh,
We are evaluating the same board under QNX 6.3.2 now. There are some other changes we would like in the updated version
I tried your 6.3.2 driver attached to the earlier message and I get a little different errors:
using the mount command:
mount -Tio-net -ovid=0x10ec /lib/dll/devn-rtl8169.so
mount: can't mount / (type io-net)
mount: Possible reason: Invalid argument
unable to load dll npm-tcp: Library cannot be found
The driver you compiled for 6.3.0 has been working for us for several months with out a problem. Could you look at this
for us?
Mark
07/13/2010 10:26 AM
post59295
Please try this one.
Thanks, Hugh.
On 10-07-13 10:09 AM, "Mark Dornbush" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> changes we would like in the updated version.
> different errors:
> with out a problem. Could you look at this for us?
> Thanks,
> Mark
>> -----Original Message-----
> Networking Drivers
> http://community.qnx.com/sf/go/post59286
Hugh Brown (613) 591-0931 ext. 2209 (voice)
QNX Software Systems Ltd. (613) 591-3579 (fax)
175 Terence Matthews Cres. email: hsbrown@qnx.com
Kanata, Ontario, Canada.
K2M 1W8
09/28/2009 12:55 PM
post38900
Please will you try this version?
Thanks, Hugh.
[io-net]
Options []
Mark
Networking Drivers
09/28/2009 4:25 PM
post38925
Sure! I'll happily try any version...
This version works, I'm running tcp/ip and qnet on it now. I will stress test it overnight but I don't expect any
problems.
Thank you very much for your support!
02/04/2010 4:34 PM
post46601
Hi Hugh,
We've done more testing with this driver and been having trouble with io-net core dumping. We've been using QNX 6.3 for
years with different NICs and this is the first time we've had io-net crash on us. We suspect this driver is the cause
Is there a way to trouble shoot this?
Mark
02/05/2010 7:35 AM
post46639
Unfortunately the 6.4 drivers are written for io-pkt, which is completely
different from io-net. You will have to speak to your account manager to
request a back-port.
Hugh.
On 10-02-04 4:34 PM, "Mark Dornbush" <community-noreply@qnx.com> wrote:
> Hi Hugh,
> core dumping. We've been using QNX 6.3 for years with different NICs and this
> cause.
> Thanks,
> Mark
> Networking Drivers
> http://community.qnx.com/sf/go/post46601
02/05/2010 8:39 AM
post46652
Why is it that QNX 4 gets updated network drivers released for free (via the QNX 4 Product Suite 2009 CD) and no updates
for versions of QNX 6?
02/05/2010 10:08 AM
post46676
Nobody said anything about paying for this! The time has to be scheduled to
do this and has to be requested through the right channels.
> QNX 4 Product Suite 2009 CD) and no updates for versions of QNX 6?
> Networking Drivers
> http://community.qnx.com/sf/go/post46652
