09/17/2009 9:56 AM
post38158
In dev_attach function /sys/Device_qnx.c
Prototype :
int dev_attach(char *drvr,
char *options, struct cfattach *ca,
void *cfat_arg,
int *single, /* 4th argument */
struct device **devp,
int (*print)(void *, const char *))
Can you please tellme what is the 4th argument. i will not found any explanation for this...
Please help me on this.
Thanks and Regards
K.Senthil
09/17/2009 11:48 AM
post38178
From my understanding, if the unit=x is specified in command line
arguments, single is set to true(1), probably to indicate the caller
that dev_attach need not to be called again because we have to bring
only 1 interface as specified by user.
BR,
Akash
Sent: Thursday, September 17, 2009 7:27 PM
To: drivers-networking
Subject: dev_attach function
Prototype :
void *cfat_arg,
Thanks and Regards
K.Senthil
Networking Drivers
http://community.qnx.com/sf/go/post38158
Re: RE: dev_attach function
09/18/2009 9:39 AM
post38274
i loading the driver using mount command.
if i specify the unit=1 on mount command.it throws an error.
Where i can specify unit option?
Thanks and Regards
K.Senthil
09/18/2009 9:42 AM
post38276
On Fri, Sep 18, 2009 at 09:39:46AM -0400, Senthil K wrote:
Please post the mount command.
09/18/2009 10:04 AM
post38278
Hi ,
The following command i used to load the driver.
mount -T io-pkt devnp-xxx.so unit=1
Thanks and Regards
K.Senthil
09/18/2009 10:06 AM
post38281
On Fri, Sep 18, 2009 at 10:04:50AM -0400, Senthil K wrote:
> Hi ,
Should be:
mount -T io-pkt -ounit=1 devnp-xxx.so
09/18/2009 10:27 AM
post38296
Hi Sean,
I am using the sample ethernet driver.
If i gave the mount command with the option unit=1,
system gets hung.
Thanks and Regards
K.Senthil
09/18/2009 10:36 AM
post38300
On Fri, Sep 18, 2009 at 10:27:12AM -0400, Senthil K wrote:
> Hi Sean,
> system gets hung.
Seems to work here. Can you be more detailed?
09/18/2009 11:08 AM
post38313
Hi Sean,
I got following error.
mount -T io-pkt -ounit=1 /lib/dll/devnp-PE.so
mount: Can't mount / (type io-pkt)
mount: Possible reason: No such device
Please tell me why the single variable is set to 1(What it mean) in the below function.
int
sam_entry(void *dll_hdl, struct _iopkt_self *iopkt, char *options)
int instance, single;
struct device *dev;
void *attach_args;
/* parse options */
/* do options imply single? */
single = 1;
/* initialize to whatever you want to pass to sam_attach() */
attach_args = NULL;
for (instance = 0;;) {
/* Apply detection criteria */
/* Found one */
dev = NULL; /* No Parent */
if (dev_attach("sam", options, &sam_ca, attach_args,
&single, &dev, NULL) != EOK) {
break;
dev->dv_dll_hdl = dll_hdl;
instance++;
if (/* done_detection || */ single)
break;
if (instance > 0)
return EOK;
return ENODEV;
Thanks and Regards
K.Senthil
09/18/2009 11:18 AM
post38315
On Fri, Sep 18, 2009 at 11:08:36AM -0400, Senthil K wrote:
> Hi Sean,
It's an example. Often drivers scan in a loop detecting
all instances of hardware they're to handle. single = 1
means stop scaning. There's no real hardware in the sample
driver; it's an example.
> int
> struct device *dev;
> void *attach_args;
> /* parse options */
> single = 1;
> attach_args = NULL;
> /* Found one */
> break;
> instance++;
> break;
> if (instance > 0)
> return EOK;
> return ENODEV;
> Thanks and Regards
> K.Senthil
> Networking Drivers
> http://community.qnx.com/sf/go/post38313
09/28/2009 1:38 AM
post38845
Hi Sean,
i tried the following approach in sample driver(devnp-sample.so).
Approach 1:
mount -T io-pkt -ounit=1 devnp-sample.so then i do
#ifconfig
sam1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
address: 00:01:02:03:04:05
Approach 2:
mount -T io-pkt -ounit=10 devnp-sample.so then i do
#ifconfig
sam10: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
Approach 3:
I changed single variable value as 0 instead of 1,then
#ifconfig
Why i m telling different apprach,there is no difference if i changed the variable single as
as 0. I m not able to understand how the relation between the single varaible and unit option in the mount command.
Can you please help me.
Thanks and Regards
K.Senthil
09/28/2009 9:16 AM
post38859
On Mon, Sep 28, 2009 at 01:38:03AM -0400, Senthil K wrote:
> Hi Sean,
> Approach 1:
> #ifconfig
> Approach 2:
> #ifconfig
> Approach 3:
> #ifconfig
There is no relation between 'unit' and single. Unit
is working as expected in the examples above. The
sample driver doesn't scan in a loop so in effect single=1
always.
Try putting two pci cards of the same type in a machine,
start the driver with no args, then try passing the pci
index of one of them to see the effect of single = 0 vs
single = 1.
