08/17/2009 10:54 AM
post36098
On Mon, Aug 17, 2009 at 10:31:24AM -0400, Senthil K wrote:
> Hi Sean,
> The link which you have sent useful and it has general gdb commands.
> but i want to debug io-pkt is there any way to do.
Sure, I do it all the time...
There's nothing special about io-pkt. From gdb's point
of view it's a process like any other. All the info
in the gdb docs should apply.
> Because in qnx we using mount command then only the io-pkt will load in to qnx stack.
- You can start your driver from the io-pkt command line
- gdb 'run' or 'set args' commands
- Run io-pkt with no args in gdb and run the mount command
from another console.
