Forum Topic - i.mx35 FEC PHY question:
Hi.
A customer is looking to use the i.mx35 in a custom design and wants to know if we already support the LAN8710 PHY. I
think that the answer is yes, since they tell me it is the PHY used on the Freescale reference 3DS board for the onboard
 FEC - but they are making a design decision (before their 3DS board arrives) so they want to be sure that we can
support it. The device saves them $10 and is smaller and uses less power than the alternatives...
The FEC source does not mention the PHY except generically...
Anyone able to confirm this ?
Thanks !
Dave
RE: i.mx35 FEC PHY question
There is an IEEE standard for the PHY registers,
which is what matters from a software standpoint.
Any PHY manufactured within the last 5+ years will
conform to the standard, which means that our libdrvr
should talk to it.
About the only place that hardware guys get to express
their artistic creativity is the address of the PHY
on the PHY bus, which is an integer between the values
of 0 and 31 inclusive.  Most of the drivers either can
take a command line option for this, or will scan
for the PHY.
aboyd
Re: i.mx35 FEC PHY question
Hi Andrew,
Thanks for the reply - I'll take that as a 'yes' then.
I wish I was as confident as you with PHYs - the 8360 ucc_ec driver is
proving much less forgiving ofor instance - our reference board uses a
Marvell PHY, for which we have custom code, while my customer's
reference board (RDK instead of MDS) uses Broadcom parts for the GigE
NICs, and something else for the 10/100s, and doesn't 'just work'...
Thanks !
Daave
> should talk to it.
> for the PHY.
> aboyd
> Networking Drivers
> http://community.qnx.com/sf/go/post30442
Dave Bott (dbott@qnx.com)	Field Applications Engineer
QNX Software Systems, Inc.	Cell:408 391-3535
San Jose CA
Join Foundry27 <http://community.qnx.com>;  - the new QNX developer forum.
99% of the time, you just need to get the mii_read()
and mii_write() functions working correctly - and
they can be a bit tricky, spinning with timeouts -
but after that, as I said, the PHY address is about
all there is to worry about.
The last time we had to fix a bug in the libdrvr
(which is statically linked into the network driver,
and provides the MDI_ functions) was years ago, when
either Hugh or xtang had to bump up a field from a
byte to an unsigned for gige.
I am assuming that you are using auto-negotiation
for link speed and duplex, which is the other common
pothole for network drivers in years past.
I really wish we had never added speed annd duplex
options to the drivers, because almost all the time
they create more problems than they solve.
aboyd
