(BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/05/2009 11:23 PM
post28757
Hi there,
I'm new to QNX, and installed QNX 6.4 and need the networking feature, as I
am testing a middleware.
I have two network card in my dell precision T7400. They are both Broadcom.
The pidin returns a
(BCM5721 and BCM5724) NetXtreme Gigabite Ethernet PCI Express - and the
"shim" only picks up one of them!
Does QNX 6.4 have a device deriver for these models!
I did a search and realised most of the Broadcom cards have "devn-tigon3.so"
1) Is it compatible for 6.4?
2) How do I download the driver, and install it please.
Amir Sadrossadat
RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/06/2009 7:59 AM
post28775
Please can you supply the output from 'pci -v' so that I can see what
device IDs you have?
From: Amir Sadrossadat [mailto:community-noreply@qnx.com]
Sent: Tuesday, May 05, 2009 11:23 PM
To: drivers-networking
Subject: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express -
Hi there,
as I
Broadcom.
The pidin returns a
"devn-tigon3.so"
Amir Sadrossadat
Networking Drivers
http://community.qnx.com/sf/go/post28757
Re: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/12/2009 3:54 AM
post29222
Thank you Hugh, Andrew, and also Andy from Symmetry.
1)The Vendor ID for both is 14e4h (Broadcom).
2) I did attempt to add following two lines into my /etc/rc.d/rc.local
*) ‘slay –fQ io-pkt-v4-hc’ and ran
**) 'io-pkt-v4-hc -d tigon3 did=0x14e4h vid=0x1659h -d tigon3 did=0x0x14e4h, vid=0x167ah
3) When I reboot “ifconfig” shows (en0) and (en1). which is great :)
4) I then use the configuration->network and add in the ip-addresses, and make it enable, and all is good. I can ping
and see my networks. However, when I restart the machine, It all goes back to only one “en0” again! My guess is the
fact of reloading the driver “in rc.local” clears any saved setting!!
Another *driver* problem that I have had is the configurator->display drive. The Driver has been picked up as "vesabios"
. The HW/Details shows a "nVidia, Quadro FX 1700, vid= 0x10de did=0x40f index=1", and the QNX hardware site suggests a "
devg-tnt.so" for all nVidia family! Does 6.4 supports this H/W?
I’ve added a line to the /etc/system/enum/drivers/graphics it now comes with the “fatal error popup window saying,
Load_display_info(): unable to for “0x10de,0x40f,1” Which I can only "EXIT".
*) I can’t log in as super user! So I am kind of stuck!
I appreciate your input here.
Many thanks,
Amir
RE: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/12/2009 8:02 AM
post29236
The 167a device ID was not in our driver, so that is why you only got
en0. I have attached an experimental driver with that device ID added.
Please try it and let us know if it solves the problem.
Hugh.
Sent: Tuesday, May 12, 2009 3:54 AM
Subject: Re: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI
*) 'slay -fQ io-pkt-v4-hc' and ran
3) When I reboot "ifconfig" shows (en0) and (en1). which is great :)
and make it enable, and all is good. I can ping and see my networks.
However, when I restart the machine, It all goes back to only one "en0"
again! My guess is the fact of reloading the driver "in rc.local" clears
any saved setting!!
drive. The Driver has been picked up as "vesabios". The HW/Details shows
hardware site suggests a "devg-tnt.so" for all nVidia family! Does 6.4
supports this H/W?
I've added a line to the /etc/system/enum/drivers/graphics it now comes
with the "fatal error popup window saying, Load_display_info(): unable
to for "0x10de,0x40f,1" Which I can only "EXIT".
*) I can't log in as super user! So I am kind of stuck!
Many thanks,
Amir
Networking Drivers
http://community.qnx.com/sf/go/post29222
05/13/2009 1:10 AM
post29328
Thank Hugh,
I can't log in to my machine at the moment :(
Read the following ...
The Driver has been picked up as "vesabios". The HW/Details shows a "nVidia,
suggests a "devg-tnt.so" for all nVidia family! Does 6.4 supports this H/W?
I've added a line to the /etc/system/enum/drivers/graphics it now comes with
the "fatal error popup window saying, Load_display_info(): unable to for
I try to log out, and 'Exit to text mode" but it hangs!
From: Hugh Brown [mailto:community-noreply@qnx.com]
Sent: Tuesday, 12 May 2009 10:03 PM
Subject: RE: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI
The 167a device ID was not in our driver, so that is why you only got en0. I
Hugh.
again! My guess is the fact of reloading the driver "in rc.local" clears any
saved setting!!
Many thanks,
Amir
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post29236
05/13/2009 8:06 AM
post29339
I am not a graphics person, so I will forward your question to a
graphics person. AFAIK the nVidia chips are not supported by QNX. To
overcome your problem, boot from the installation CD and choose the "run
from CD" option. You can then look under /fs to find your disk
partition, then "cd /fs/your_partition/etc/system/config". Then you can
do a "> nophoton" and reboot your machine without the CD. You can then
login in text mode.
Sent: Wednesday, May 13, 2009 1:11 AM
Thank Hugh,
drive.
"nVidia,
site
H/W?
with
en0. I
Hugh.
and
any
saved setting!!
drive.
"nVidia,
site
H/W?
with
Many thanks,
Amir
Networking Drivers
Networking Drivers
Networking Drivers
http://community.qnx.com/sf/go/post29328
05/14/2009 2:50 AM
post29414
Thank you Hugh,
I have overcome the Display problem, I seems that there is NO deriver for
this?!
*) I have downloaded and replace the .so file in the /lib/dll but still the
same problem!
When setting the ip address using the gui they are still not being retained?
So I have manually added the "ifconfig en0 192.168.1.2" how do I set the
"dhcp" for the other network interface?
**) Also both of the drives still have the SHIM flag on, is it normal?
Shouldn't it have the tigon3 or something similar!
Many thanks
Amir
P.S -One of the network cards is BCM5754 and I typed it in as BCM5724.
Sent: Wednesday, 13 May 2009 10:07 PM
I am not a graphics person, so I will forward your question to a graphics
person. AFAIK the nVidia chips are not supported by QNX. To overcome your
problem, boot from the installation CD and choose the "run from CD" option.
You can then look under /fs to find your disk partition, then "cd
/fs/your_partition/etc/system/config". Then you can do a "> nophoton" and
reboot your machine without the CD. You can then login in text mode.
Thank Hugh,
I can't log in to my machine at the moment :( Read the following ...
Hugh.
saved setting!!
suggests a "devg-tnt.so" for all nVidia family! Does 6.4 supports this...
05/14/2009 7:46 AM
post29416
I have no idea why the gui is not working. I just realized that you will
also have to update your /etc/system/enum/devices/net file. Search for
tigon3 in the file and then copy one of the existing lines and edit it
to add the new device ID (167a). Once you reboot the machine, both
interfaces should come up.
Sent: Thursday, May 14, 2009 2:50 AM
Thank you Hugh,
for
this?!
the
same problem!
retained?
Many thanks
Amir
graphics
your
option.
and
Thank Hugh,
drive.
"nVidia,
site
H/W?
with
en0. I
Hugh.
4) I then use the...
05/18/2009 7:56 PM
post29632
Hi Hugh,
It now picks up both of the nic.
Cheers,
Amir
Sent: Thursday, 14 May 2009 9:46 PM
tigon3 in the file and then copy one of the existing lines and edit it to
add the new device ID (167a). Once you reboot the machine, both interfaces
should come up.
Thank you Hugh,
this?!
same problem!
Many thanks
Amir
option.
and
Thank Hugh,
Hugh.
2)...
Re: RE: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/18/2009 8:49 PM
post29633
Hugh,
It solves the problem. Thank you.
Amir
RE: RE: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet PCI Express - Device Drive for QNX 6.4
05/19/2009 7:58 AM
post29653
Good news!
Thanks, Hugh.
Sent: Monday, May 18, 2009 8:50 PM
Subject: Re: RE: RE: (BCM5721 and BCM5724) NetXtreme Gigabit Ethernet
Hugh,
Amir
Networking Drivers
http://community.qnx.com/sf/go/post29633
05/06/2009 10:00 AM
post28804
devn-tigon3.so is the io-net driver for broadcom 57xx
nics - it runs under the shim with io-pkt on 6.4
devnp-bge.so is a port of the BSD driver for the
broadcom 57xx nics.
As Hugh says, we need the output of
# pci -v
to figure out which DID you have.
aboyd
