Forum Topic - IPv6 configuration using io-pkt-v6-hc:
Besides starting io-pkt-v6-hc and configuring an address using ifconfig,
what else needs to be configured to run IPv6?
I am attempting to run io-pkt-v6-hc with both IPv4 and IPv6 addresses
assigned.  My basic test has two blades connected to each other such
that I can attempt a ping and ping6 to the other blade (from either
end).
Success:
-        IPv4 ping on both cards
-        IPv4 ping of local address (127.0.0.1)
-        IPv4 ping of local configured address
-        IPv6 ping of local address (::1)
-        IPv6 ping of local configured address
Failure:
The IP configuration and test results, for the ping and ping6 attempts
between the cards, are captured below.  I've checked most of the
ifconfig and io-pkt documentation as well as the io-net migration and
driver threads without finding any similar threads.
Cheers,
maurice
Background
I have already used io-net in the past.  To limit the change, I've had a
designer here run the io-pkt-v6 with our original devn-ppc405 (e.g.
access using the shim).
Blade 1 - IP=10.13.128.98
Blade 2 - IP=10.13.128.55
Configuration of Both Blades
Blade 2:
slogger -s 64k -l /tmp/slogs,64k&
io-pkt-v6-hc -v
mount -T io-pkt -o mac=00019c0006ce,deviceindex=0,verbose=2
devn-ppc405.so
ifconfig en0 inet6 fe80::201:9cff:fe00:6ce
ifconfig en0 10.13.128.55 netmask 0xfffffc00
route -q add default 10.13.128.2
# ifconfig
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu
1500
        address: 00:01:9c:00:06:ce
        inet 10.13.128.55 netmask 0xfffffc00 broadcast 10.13.131.255
        inet6 fe80::201:9cff:fe00:6ce%en0 prefixlen 64 scopeid 0x2
Process 696338 (ifconfig) exited status=0.
Blade 1:
io-pkt-v6-hc -v
mount -T io-pkt -omac=00019c000477,deviceindex=0,verbose=2
devn-ppc405.so
ifconfig en0 inet6 fe80::201:9cff:fe00:477
ifconfig en0 10.13.128.98 netmask 0xfffffc00
# ifconfig
1500
        address: 00:01:9c:00:04:77
        inet 10.13.128.98 netmask 0xfffffc00 broadcast 10.13.131.255
        inet6 fe80::201:9cff:fe00:477%en0 prefixlen 64 scopeid 0x2
Process 319506 (ifconfig) exited status=0.
Ping Results from Blade1
# ping -c4 -vv 10.13.128.55
PING 10.13.128.55 (10.13.128.55): 56 data bytes
Destination Port Unreachable
 Vr HL TOS  Len   ID Flg  off TTL Pro  cks      Src          Dst
  4  5  00 0047 0158   0 0000  40  11 0000       127.0.0.1  127.0.0.1
  UDP: from port 65528, to port 53
  4  5  00 0047 015a   0 0000  40  11 0000       127.0.0.1  127.0.0.1
  UDP: from port 65527, to port 53
64 bytes from 10.13.128.55: icmp_seq=0 ttl=255 time=5 ms
64 bytes from 10.13.128.55: icmp_seq=1 ttl=255 time=1 ms
64 bytes from 10.13.128.55: icmp_seq=2 ttl=255 time=1 ms
64 bytes from 10.13.128.55: icmp_seq=3 ttl=255 time=1 ms
----10.13.128.55 PING Statistics----
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max =...
