03/25/2009 9:56 PM
post25270
I am trying to modify the FreeBSD code if_bnx.c to include support for BCM5709S chipset. As part of that, I would like
to know where should I add the routine to initialzing 5709 for SERDES mode of operation. Does it have to be under /sys/
dev/mii directory? I see a buch of files there with support for diffrenet PHY types.
Secondly, what is the chain of function calls that would finally lead to that init routine being called.
Thanks for your help
Tanmay
03/26/2009 10:23 AM
post25344
Unfortuantely, we don't have any SERDES hardware implementations
in-house... sys/dev/mii generally does deal with specific PHY
implementations, but unless there's a specific SERDES implementation in
the FreeBSD if_bnx code, there shouldn't be any need to update that
portion of the library. If this is custom code, I'd say that the best
place to do it will likely be in the hardware initialization function
which is called whenever the interface is configured.
R.
From: Tanmay Kishore [mailto:community-noreply@qnx.com]
Sent: Wednesday, March 25, 2009 9:57 PM
To: drivers-networking
Subject: BCM5709S
BCM5709S chipset. As part of that, I would like to know where should I
it have to be under /sys/dev/mii directory? I see a buch of files there
Tanmay
Networking Drivers
http://community.qnx.com/sf/go/post25270
03/26/2009 2:42 PM
post25385
Thanks!!! I will try the freeBSD code without any modification for SERDES and see what happens. On a differenet note,
when I try to load io-pkt using the following command:
io-pkt-v4 -d bnx,
I get the following error: unknown symbol: pci_get_function. pci_get_function is a FreeBSD function. What is its
equivalent in QNX?
Thanks again for your help.
Tanmay.
03/26/2009 2:49 PM
post25387
I had a quick look through the NetBSD bnx source and couldn't find that
function. Where is it getting called from?
R
Sent: Thursday, March 26, 2009 2:42 PM
Subject: Re: RE: BCM5709S
SERDES and see what happens. On a differenet note, when I try to load
io-pkt-v4 -d bnx,
pci_get_function is a FreeBSD function. What is its equivalent in QNX?
Tanmay.
Networking Drivers
http://community.qnx.com/sf/go/post25385
03/26/2009 3:25 PM
post25393
the ndame of the function is bnx_get_media in if_bnx.c. I am not sure if you have the latest file with you or not.
Otherwise, you can try looking up in the latest linux source code repository and you can find this function in the
if_bnx2.c file.
Tanmay
03/26/2009 3:34 PM
post25394
Hmmm... I'm looking at version 1.23 of the source and there doesn't seem
to be a bnx_get_media function in the file.
http://cvsweb.netbsd.org/bsdweb.cgi/src/sys/dev/pci/if_bnx.c?rev=1.23&co
ntent-type=text/x-cvsweb-markup
Obviously the linux code base is going to do Something Different from
the NetBSD source base and there may be no equivalent function for it.
R.
Sent: Thursday, March 26, 2009 3:26 PM
Subject: Re: RE: RE: BCM5709S
you have the latest file with you or not. Otherwise, you can try looking
function in the if_bnx2.c file.
Tanmay
Networking Drivers
http://community.qnx.com/sf/go/post25393
03/26/2009 5:03 PM
post25403
So here's the link to directory containing the latest FreeBSD files:
http://www.freebsd.org/cgi/cvsweb.cgi/src/sys/dev/bce/
If you look at the if_bnx.c, you should be able to find the function bnx_get_media(). Or look for pci_get_function().
Tanmay
03/26/2009 5:08 PM
post25404
Ah.... You're using the FreeBSD driver. I thought that you'd said you
were using the NetBSD driver.
Unfortunately, I think that you'll have to dig into the FreeBSD source a
bit more to figure out what that pci call does... I'm not sure of what
the equivalent code would be for Neutrino.
R.
Sent: Thursday, March 26, 2009 5:04 PM
Subject: Re: RE: RE: RE: BCM5709S
Tanmay
Networking Drivers
http://community.qnx.com/sf/go/post25403
Re: RE: RE: RE: RE: BCM5709S
03/26/2009 5:13 PM
post25406
Thanks for all your help. Your response time is amazing. Keep up the good work.
Tanmay
04/07/2009 6:02 PM
post26294
So, I could finally get to a stage where the 5709 driver can detect the SERDES PHY. But unfortunately, it compalins
about "no carrier" when I run the ifconfig command. In my log, I see the gentbi.c phy driver getting executed and it
detects the PHY device twice, once for phy address = 2, and the next one for phy address == 3. Here's the log:
gentbi2 at bnx2 phy 2: Generic ten-bit interface, rev. 0
gentbi2: 1000baseSX, 1000baseSX-FDX, auto
Find PHY, oui = 00000af7, model = 0000003f
gentbi3 at bnx2 phy 31: Generic ten-bit interface, rev. 0
gentbi3: 1000baseSX, 1000baseSX-FDX, auto
These logs are from mii.c:mii_attach() and gentbi.c:gentbiattach() function calls. The locations of the files is under
sys/dev/mii folder. What I am not able to understand is why the gentbiattach function executes twise for the same device
Secondly, the output of ifconfig shows no carrier detect under the status field. Here's the output:
>ifconfig
bnx0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 1500
capabilities=7<IP4CSUM,TCP4CSUM,UDP4CSUM>
enabled=0
address: 00:10:18:49:7b:d4
media: Ethernet autoselect
status: no carrier
inet 172.22.130.12 netmask 0xffffff00 broadcast 172.22.130.255
bnx2: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
enabled=0
address: 00:10:18:49:7b:d0
status: no carrier
As you can see, the status shows up as no carrier. Do you guys know what could be causing this? I can send you some
status register dumps if that helps. But you will have to ask specifically which dump are you interested in.
Tanmay
RE: RE: RE: RE: RE: BCM5709S
04/13/2009 12:08 PM
post26785
Hi Tanmay:
Unfortunately, I can't think of anything offhand that would
explain this. The phy 31 is a bit suspicious (since the phy addresses
range from 0 to 31), but I don't know why it would show up.
Again, with no hardware in house and no experience with SERDES as such,
we're as much in the dark as you are. Do you have docs for the card
that you can use to help diagnose the problem?
R.
Sent: Tuesday, April 07, 2009 6:02 PM
Subject: Re: RE: RE: RE: RE: BCM5709S
SERDES PHY. But unfortunately, it compalins about "no carrier" when I
getting executed and it detects the PHY device twice, once for phy
function calls. The locations of the files is under sys/dev/mii folder.
executes twise for the same device.
>ifconfig
enabled=0
status: no carrier
enabled=0
status: no carrier
could be causing this? I can send you some status register dumps if that
interested in.
Tanmay
Networking Drivers
http://community.qnx.com/sf/go/post26294
