RE: ep8260 6.4.0 - no receive packets
01/19/2009 9:38 PM
post20359
Hi Dave:
So... Either the interrupt isn't firing OR the PHY that you think that you're connected to isn't the one that you're
actually connected to. Are there multiple interfaces on the board? Did this BSP work on the same hardware with 6.3.2?
Robert.
Sent: Mon 1/19/2009 7:27 PM
To: drivers-networking
Subject: ep8260 6.4.0 - no receive packets
Customer has migrated Embedded Planet 8260 BSP to 6.4.0
Using io-net driver with shim, things come up and appear to start, but nicinfo shows no packets received...
Here are sloginfo, pidin info, ifconfig and nicinfo output. IRQ 0x20 appears to be the required one.
Suggestions welcome !
Dave
EP8260_MAC=0010EC007E65
EP8260_IP1=10.1.0.112
io-pkt-v4 -dppc8260-ep channel=1,mac=EP8260_MAC,verbose -vvvvvvvvvv
waitfor /dev/socket
ifconfig en0 $EP8260_IP1
Here's what's in my slog:
Jan 01 00:30:41 5 14 0 tcpip starting
Jan 01 00:30:41 3 14 0 Unable to attach to pci server: No such
file or
directory
Jan 01 00:30:41 3 14 0 Using pseudo random generator. See
"random" op
tion
Jan 01 00:30:41 5 10 0 PPC 8260
Jan 01 00:30:41 5 10 0 Vendor .............. 0x0
Jan 01 00:30:41 5 10 0 Device .............. 0x0
Jan 01 00:30:41 5 10 0 Revision ............ 0x0
Jan 01 00:30:41 5 10 0 Interrupt ........... 0x20
Jan 01 00:30:41 5 10 0 MAC address ......... 0010ec 007e65
Jan 01 00:30:41 5 10 0 devn-ppc8260: MII transceiver found at
address
0.
Jan 01 00:30:41 5 14 0 io-pkt shim
Jan 01 00:30:41 5 14 0 Vendor .............. 0x0
Jan 01 00:30:41 5 14 0 Device .............. 0x0
Jan 01 00:30:41 5 14 0 Revision ............ 0x0
Jan 01 00:30:41 5 14 0 MAC address ......... 0010ec 007e65
Jan 01 00:30:44 5 10 0 devn-ppc8260: link up (100 MBPS Full
Duplex)
Jan 01 00:33:12 5 10 0 devn-ppc8260: shutdown1()
Jan 01 00:33:12 5 10 0 devn-ppc8260: shutdown2()
Jan 01 00:34:04 5 14 0 tcpip starting
# ifconfig -a
en0: flags=80008843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST,SHIM> mtu
1500
address: 00:10:ec:00:7e:65
inet 10.1.0.112 netmask 0xff000000 broadcast 10.255.255.255
# pidin irqs
pid tid name
1 1 c/boot/procnto-600
0 0x80000000 0 -P- @0x57398:0x0
1 2 c/boot/procnto-600
1 3 c/boot/procnto-600
1 4 c/boot/procnto-600
1 5 c/boot/procnto-600
1 6 c/boot/procnto-600
1 7 c/boot/procnto-600
1 8 c/boot/procnto-600
1 9 c/boot/procnto-600
1 10 c/boot/procnto-600
1 11 c/boot/procnto-600
1 12 c/boot/procnto-600
2 1 ot/devc-serppc8260
2 2 ot/devc-serppc8260
1 0x4 26080 --- =INTR
3 1 proc/boot/slogger
4 1 proc/boot/pipe
4 2 proc/boot/pipe
4 3 proc/boot/pipe
4 4 proc/boot/pipe
4 5 proc/boot/pipe
8198 1 proc/boot/devf-ppc
8198 3 proc/boot/devf-ppc
8198 4 proc/boot/devf-ppc
159753 1 bin/devc-pty
172042 1 bin/mqueue
217093 1 proc/boot/ksh
729099 1 bin/inetd
1474567 1 bin/io-pkt-v4
1474567 2 bin/io-pkt-v4
2 0x80000000 0 T-- @0x4808131c:0x480d2fc0
3 0x20 0 TP- =PULSE 0x4000000f:21 0:0
1474567 3 bin/io-pkt-v4
1691656 1 proc/boot/pidin
# nicinfo
en0:
PPC Embedded Planet 8260 Ethernet Controller
Physical Node ID ........................... 000000 000000
Current Physical Node ID ................... 0010EC 007E65
Current Operation Rate ..................... 100.00 Mb/s full-duplex
Active...
01/20/2009 9:02 AM
post20372
Generally, no rx packets is usually caused by
the interrupt not firing. However, I did notice
this in ths sloginfo:
which I am not sure I understand.
aboyd
