RE: QNX installation... NIC not comming up
01/16/2009 11:19 AM
post20218
> Vendor ID = 100bh, National Semiconductor Corporation
> Device ID = 20h, DP83815
That vid/did should be supported by the (io-net) devn-ns83815.so
driver. There should be a copy of it in your /lib/dll/ directory.
If there is not, grab an (experimental) copy from here:
www.pittspecials.com/etc/devn-ns8315.so
and put it in your /lib/dll directory. I really, really
hate attachments.
Then, ensure that there are no other copies of io-pkt
running:
# pidin | grep io-pkt
If so, use the "slay" command to get rid of them, ie:
# slay io-pkt-v4-hc
Now, wipe the sloginfo log:
# sloginfo -c > /dev/null
And start io-pkt and the driver like this:
# io-pkt-v4-hc -d ns83815 verbose=100
which will result in io-pkt-v4-hc loading the
"shim" driver (necessary to run io-net drivers)
and the io-net driver, devn-ns83815.so
Now you can run:
# sloginfo
and see what the driver is saying, and
# ifconfig -v
to see what the status of en0 is, and
# nicinfo
to get even more driver information
aboyd
01/16/2009 11:21 AM
post20219
Argh. Typo in URL. Try:
www.pittspecials.com/etc/devn-ns83815.so
aboyd
