Re: wpi (Intel 3945abg) Memory Allocation Errors on Receive > 0
01/12/2009 9:44 AM
post19842
"Allocation error on receive" could be due to a couple
of things in the wpip driver. This stat is actually
printing out ifp->if_ierrors (same count as 'netstat -in').
Try running just the wpi driver without the 'pagesize' and
'mclsize' args and check the sloginfo.
On Sun, Jan 11, 2009 at 05:04:17PM -0500, Ben Voigt wrote:
> Some background information:
> Asus Z96J laptop
> Intel Core2Duo, QNX 6.4 SMP kernel (installed from SDP LiveCD)
> 4GB RAM (some unmappable due to 32-bit address limitations in the northbridge) so the allocation error is
configuration, not lack of resources
> EIDE HDD
> EIDE DVD-RW
> eSATA and USB ports (not used in this configuration but drivers may be loaded during boot by enum-devices)
> RealTek 8169 Gigabit Ethernet Controller (en0)
> Intel 3945ABG wireless (wpi0)
> The 8169 wired ethernet was recognized by the QNX LiveCD.
> Grabbed core-networking via SSH, built for x86 and installed, grabbed the firmware file off the net as suggested in
the wpi driver readme.
> Created wpa_supplicant.conf with my WPA Personal preshared key.
> Using these commands to load the wpi driver (mount because the TCP/IP stack is already running to support the wired
interface):
> <code>
> # cat /root/startwifi.sh
> mount -T io-pkt -o "firmware=/etc/firmware/wpi-3945abg,pagesize=8192,mclsize=8192" /usr/qnx640/target/qnx6/x86/lib/dll
/devnp-wpi.so
> ifconfig wpi0 up
> dhcp.client -i wpi0 &
> wpa_supplicant -B -Dbsd -iwpi0 -c /etc/wpa_supplicant.conf
> </code>
> (Side note: where is the right place to load this on boot? Add to /etc/rc.d/something ?)
> The Problem:
> <code>
> # nicinfo
> en0:
> Link is DOWN
> Physical Node ID ........................... 001BFC 45AABD
> Current Physical Node ID ................... 001BFC 45AABD
> Current Operation Rate ..................... Unknown
> Active Interface Type ...................... MII
> Active PHY address ....................... 0
> Maximum Transmittable data Unit ............ 1514
> Maximum Receivable data Unit ............... 1514
> Hardware Interrupt ......................... 0xa
> I/O Aperture ............................... 0xd800 - 0xd8ff
> Memory Aperture ............................ 0xfeaffc00 - 0xfeaffcff
> Promiscuous Mode ........................... Off
> Multicast Support .......................... Enabled
> Packets Transmitted OK ..................... 30132
> Bytes Transmitted OK ....................... 684
> Memory Allocation Failures on Transmit ..... 0
> Packets Received OK ........................ 44498
> Bytes Received OK .......................... 0
> Broadcast Packets Received OK .............. 161
> Multicast Packets Received OK .............. 240
> Memory Allocation Failures on Receive ...... 0
> Single Collisions on Transmit .............. 0
> Transmits aborted (excessive collisions) ... 0
> Transmit Underruns ......................... 80
> No Carrier on Transmit ..................... 0
> Receive Alignment errors ................... 1
> Received packets with CRC errors ........... 0
> Packets Dropped on receive ................. 0
> wpi0:
> Ethernet Controller
> Physical Node ID ........................... 0019D2 B1B291
> Current Physical Node ID ................... 0019D2 B1B291
> Current Operation Rate ..................... 0 kb/s half-duplex
> Active Interface Type ...................... Unknown
> Maximum Transmittable data Unit ............ 1500
> Maximum Receivable data Unit ............... 0
> Multicast...
