12/18/2008 1:34 AM
post18912
On one of our systems we have experienced io-pkt crash.
I am attaching a file with core and list of pci devices.
Any idea what could have gone wrong?
Thanks, PKY
12/18/2008 9:21 AM
post18929
> Thanks, PKY
Can you also attach the io-pkt-v4-hc binary, any drivers /
dlls loaded therein (looks like devnp-shim.so and devn-e1000.so)
and your libc.so.
12/18/2008 9:22 AM
post18931
I unzipped it, and sure enough, all there was,
was a core file (and the pci info).
For us to examine a core file, we need:
1) your core file (got it)
2) your io-pkt binary (didn't get it)
3) ALL the libs loaded by io-pkt, which
includes the driver .so file, perhaps
qnet, and please libc as well
To figure out what libs you need to include
in the tarball, please run:
# pidin -p io-pkt-v4-hc mem
aboyd
Re: RE: io-pktv4-hc crash
01/07/2009 5:41 AM
post19504
I hope all the files needed are in the zip file.
I use devn-e1000.so. Is devnp-e1000 driver available? I couldn't find it.
Thanks, PKY
RE: RE: io-pktv4-hc crash
01/07/2009 7:45 AM
post19511
No it isn't available yet.
From: Pavol Kycina [mailto:community-noreply@qnx.com]
Sent: Wednesday, January 07, 2009 5:42 AM
To: drivers-networking
Subject: Re: RE: io-pktv4-hc crash
it.
Thanks, PKY
Networking Drivers
http://community.qnx.com/sf/go/post19504
01/07/2009 10:50 AM
post19544
There is no core file (eg io-pkt-v4-hc.core)
in the archive.
aboyd
01/07/2009 10:58 AM
post19547
Never mind - I use the email interface to the
forums, which doesn't display previous posts.
I found the core file from 17 dec 08, and
am looking at it now.
aboyd
01/07/2009 11:13 AM
post19552
Ok, if all the binaries are in sync, you
didn't die in the (e1000) driver at all.
Looking at the backtrace for the thread
that SIGSEGV'd, it blew up in a utility
function called b_to_q() which tried to
memcpy() to a null pointer. This was all
called by pppinput() - nothing to do with
the ethernet driver (or PCI) AFAIK.
Is this difficult to reproduce? I really
don't know squat about ppp (I know a little
about pppoe) but if you want to compile
io-pkt-v4-hc with the -g -O0 flags, and
send me another core, I can try to learn
a bit more - there's only so much I can
glean from disassembling x86.
Anything interesting about your ppp
configuration, or when this core occurs?
aboyd
01/07/2009 1:30 PM
post19576
We also need to know which version of the stack is being used. Is it a
custom build, a milestone build or are you running 6.4.0?
Robert.
From: Andrew Boyd [mailto:community-noreply@qnx.com]
Sent: Wednesday, January 07, 2009 11:13 AM
Subject: RE: RE: io-pktv4-hc crash
Ok, if all the binaries are in sync, you didn't die in the (e1000)
driver at all.
memcpy() to a null pointer. This was all called by pppinput() - nothing
to do with the ethernet driver (or PCI) AFAIK.
Is this difficult to reproduce? I really don't know squat about ppp (I
know a little about pppoe) but if you want to compile io-pkt-v4-hc with
the -g -O0 flags, and send me another core, I can try to learn a bit
more - there's only so much I can glean from disassembling x86.
aboyd
Networking Drivers
http://community.qnx.com/sf/go/post19552
Re: RE: RE: io-pktv4-hc crash
01/08/2009 5:17 AM
post19612
Its 6.4.0 build, all executables are from 6.4.0 DVD downloaded from your site.
01/08/2009 5:25 AM
post19613
This problem had happened for the first time. The system uptime was about 1 week. So we don't know the way to reproduce
it at a request.
The system transfers some data with measurement station via tcp/ip/pppd/modem connection. But there is nothing special
with this pppd.
It's started in a script with following args:
speed localIP:remoteIP device nodetach lcp-echo-interval 10 lcp-echo-failure 5 connect "chat script"
After data transfer, pppd is killed
Regards, PKY
RE: RE: RE: io-pktv4-hc crash
01/08/2009 1:33 PM
post19671
01/08/2009 2:02 PM
post19677
For completeness, you should check and make sure that
you don't have a memory leak, and aren't running out of
memory on the machine.
For example, does "pidin in" show the number after
FreeMem steadily decreasing as the days go by? If so,
which process is leaking memory?
aboyd
01/20/2009 8:28 AM
post20369
The crash happened again.
I can confirm, that there was enough free memory at the time of the crash.
PKY
> aboyd
01/20/2009 9:34 AM
post20378
ok, that rules out low memory as the problem.
Unless someone has a better idea, would you be willing
to run a custom io-pkt (that I can provide you) that I
have compiled "-g -O0" so that the next time it cores,
it produces a core file with a lot more information
for me to look at?
I wish I had a better suggestion :-(
aboyd
Re: RE: RE: RE: io-pktv4-hc crash
01/21/2009 1:17 AM
post20468
Yes, I have no problem with running custom io-pkt.
Can I download it from somewhere?
Regards, PKY
> for me to look at?
> aboyd
RE: RE: RE: RE: io-pktv4-hc crash
01/21/2009 11:06 AM
post20501
www.pittspecials.com/etc/io-pkt-v4-hc
I just compiled it -g -O0. After you
download it, be sure that the size is
4,537,200 bytes, and the cksum is
14090642, then chmod it 777.
aboyd
Re: RE: RE: RE: RE: io-pktv4-hc crash
03/09/2009 9:50 AM
post23890
It took some time for a "special" io-pktv4-hc to crash.
I am attaching core file
Thanks, PKY
RE: RE: RE: RE: RE: io-pktv4-hc crash
03/09/2009 11:17 AM
post23898
> attaching core file
After carefully verifying matching binaries - it's
been almost 2 months - it looks like a different
problem. The fault occurred as a result of
NWSIGUNLOCK_P()
call at line 765 of sys/receive.c, which according
to the backtrace ended up in libc.so.3 __assert()
which called abort() then raise() then SignalKill().
The first parameters to the NWSIGUNLOCK_P() macro
was &sctlp->pkt_ex which gdb says had an "owner" of
zero, and an apparently underflowed "count" of approximately
negative two billion and change.
I will pester sean about this - I seem to recall
something similar.
aboyd
Re: RE: RE: RE: RE: RE: io-pktv4-hc crash
03/10/2009 8:40 AM
post24000
07/16/2009 2:56 PM
post33981
(gdb) p/x stk_ctl
$9 = {iopkt = 0x819b018, do_cache = 0x1, recv_max = 0x21, recv_avail = 0x21, recv_iov = 0x819fe98,
recv_mbuf = 0x819ffb8, recv_start = 0x0, recv_loaded_proc = 0x81accf8, recv_procp = 0x81accf8,
chid = 0x1, coid = 0x40000002, dpp = 0x8196068, timer_int_id = 0xe, fastforward = 0x1,
stacksize = 0x1000, rx_prio = 0x15, proc_alloc_tot = 0x4, proc_alloc_used = 0x1, allprocs = 0x8198140,
proc0 = 0x81ac1e0, freeprocs = 0x81ac9a4, nprocs_cur_max = 0xf, nprocs_used = 0x4, nprocs_min = 0xf,
nprocs_incr = 0x19, nprocs_max = 0xc8, nthreads_core = 0x1, nthreads_core_max = 0x2, nthreads_oob = 0x0,
nthreads_oob_max = 0x2, nthreads_flow_max = 0x2, nthreads_cur = 0x1, nthreads_untracked = 0x1,
nwork_threads = 0x4, work_threads = 0x8194068, quiesce_count = 0x0, stack_ex = {count = 0x80000000,
owner = 0x0}, stack_inuse = 0x0, thread_inreceive = 0x1, msg_outstanding = 0x0, pkt_ex = {
count = 0x80000000, owner = 0x0}, pkt_rx_q = 0x0, work_thread_key = 0x0, proc_prio = {
prio_prios = 0x81a0058, prio_all = {head = 0x0, tail = 0x0}}, pstats = {p_ru = {ru_utime = {
tv_sec = 0x0, tv_usec = 0x0}, ru_stime = {tv_sec = 0x0, tv_usec = 0x0}, ru_maxrss = 0x0,
ru_ixrss = 0x0, ru_idrss = 0x0, ru_isrss = 0x0, ru_minflt = 0x0, ru_majflt = 0x0, ru_nswap = 0x0,
ru_inblock = 0x0, ru_oublock = 0x0, ru_msgsnd = 0x74be6c, ru_msgrcv = 0x12ef4cb, ru_nsignals = 0x0,
ru_nvcsw = 0x0, ru_nivcsw = 0x0}, p_cru = {ru_utime = {tv_sec = 0x0, tv_usec = 0x0}, ru_stime = {
tv_sec = 0x0, tv_usec = 0x0}, ru_maxrss = 0x0, ru_ixrss = 0x0, ru_idrss = 0x0, ru_isrss = 0x0,
ru_minflt = 0x0, ru_majflt = 0x0, ru_nswap = 0x0, ru_inblock = 0x0, ru_oublock = 0x0,
ru_msgsnd = 0x0, ru_msgrcv = 0x0, ru_nsignals = 0x0, ru_nvcsw = 0x0, ru_nivcsw = 0x0}, p_timer = {{
it_interval = {tv_sec = 0x0, tv_usec = 0x0}, it_value = {tv_sec = 0x0, tv_usec = 0x0}}, {
it_interval = {tv_sec = 0x0, tv_usec = 0x0}, it_value = {tv_sec = 0x0, tv_usec = 0x0}}}, p_prof = {
pr_base = 0x0, pr_size = 0x0, pr_off = 0x0, pr_scale = 0x0, pr_addr = 0x0, pr_ticks = 0x0},
p_start = {tv_sec = 0x0, tv_usec = 0x0}}, plimit = {pl_rlimit = {{rlim_cur = 0x0, rlim_cur_hi = 0x0,
rlim_max = 0x0, rlim_max_hi = 0x0}, {rlim_cur = 0x0, rlim_cur_hi = 0x0, rlim_max = 0x0,
rlim_max_hi = 0x0}, {rlim_cur = 0x0, rlim_cur_hi = 0x0, rlim_max = 0x0, rlim_max_hi = 0x0}, {
rlim_cur = 0x0, rlim_cur_hi = 0x0, rlim_max = 0x0, rlim_max_hi = 0x0}, {rlim_cur = 0x0,
rlim_cur_hi = 0x0, rlim_max = 0x0, rlim_max_hi = 0x0}, {rlim_cur = 0x7fffffff, rlim_cur_hi = 0x0,
rlim_max = 0x7fffffff, rlim_max_hi = 0x0}, {rlim_cur = 0x0, rlim_cur_hi = 0x0, rlim_max = 0x0,
rlim_cur = 0x7fffffff, rlim_cur_hi = 0x0, rlim_max = 0x7fffffff, rlim_max_hi = 0x0}, {
rlim_cur = 0x0, rlim_cur_hi = 0x0, rlim_max = 0x0, rlim_max_hi = 0x0}}, pl_corename = 0x0,
p_lflags = 0x0, p_refcnt = 0x1}}
(gdb) p stk_ctl.work_threads[0]@4
$3 = {0x81a2880, 0x0, 0x0, 0x0}
(gdb) p *(struct nw_work_thread*)0x81a2880
$7 = {wt_critical = -1, wt_intr_pending = 0, intr_sighot = 1, am_stack = 0, blocking = 0, inreceive = 0,
tidx_wt = 0, tidx_irupt = 0, flowctl = 0x81a2b70, wt_bru = {wt_bru_brctl = 0x81950a8,
wt_bru_bridx = 0x81950a8}, wt_oob = 0x0, wt_mzones = {{p = 0x87bd500, avail = 32, max = 32}, {
p = 0x82f1f00, avail = 32, max = 32}}, jp = 0x0, intr_stack_tos = 0x81a2820 "",
saved_sp = 133831884, tls = 0x7fc6fc0, rx_loop_ctxt = {rx_loop_jmp_buf = {{__jmpbuf_un = {__savearea = {
0 <repeats 13 times>}, __alignment = 0}, __flg = 0, __msk = {0, 0}}}, rx_loop_ctxt = {cpu = {
edi = 0, esi = 0, ebp = 0, exx = 0, ebx =...
