10/31/2008 10:45 AM
post15796
On Fri, Oct 31, 2008 at 10:35:05AM -0400, Aaron Cripps wrote:
> Not sure if this is the right place to put this.
> Sean, you'll definitely want to take a look at this and/or tell me "the right way"(tm) to go about this fix ...
> I have attached a patch to net/npm/tcpip/utils.c
> What was happening was: make crapped out because of a label at the end of a compound statement.
> What I did was move the label further down, outside of the compound statement, but it *should* be in a place where the
execution of all codepaths would remain unchanged (read: there's lots of if/else in that file).
> Here ya go ...
That won't work as it now jumps past the mutex_unlock.
Moving the label just above the mutex_unlock is OK.
Guess you'll need a PR though :)
