Re: RE: Activating a '2nd' Network Adapter
09/17/2008 2:48 PM
post13580
> If you press the space bar at boot time and then press 'F6' (verbose)
> several times, you will see where the driver is being started. I guess
> that the PCI enumerator is starting the device. Have you commented out
> the lines for both adapters in the net file?
Wow, that was more debug output than I could process as it ripped by. I checked sloginfo but it doesn't look like all
the information made it in there. Did it go into another file?
As for commenting out adapters in the net file, no, I only commented out device ID 0x107c, the 2nd adapter. I left the
line in place for the 82546GB (device ID 0x1079).
