RE: Network adapter - PCI Express - integrated Ethernet Controller(s) Broadcom BCM5755
08/07/2008 4:29 PM
post11549
Hi Sharath:
If it doesn't show up with pci -v (which I'm assuming that you
run as root?), then there's no way for our drivers to work with it.
On a positive note, it looks like that specific device ID is handled by
the devn-tigon3.so driver for io-net, but there's something not right
with the way that your PCI bus is getting set up since the NIC isn't
visible to our PCI server.
Robert.
From: Sharath Bennur [mailto:community-noreply@qnx.com]
Sent: Thursday, August 07, 2008 3:25 PM
To: drivers-networking
Subject: Re: Network adapter - PCI Express - integrated Ethernet
Its an integrated NIC, when I try pci and pci -v I dont see the adapter
listed anywhere. I only see ATI and AMD devices, no reference to
broadcom. Its supposed to be an integrated PCI-express controller, is
there a different command for that?
I still have windows XP running on the same machine and the ethernet
controller is listed as - Broadcom NetXtreme Gigabit Ethernet - there.
These are the other properties I could pull out under windows:
ASIC Version: BCM5755 A2
Firmware Version: 5755-v3.29
Management Firmware: BRCM ASF v7.07
Vendor ID: 0x14E4
Device ID: 0x167B
Sub-system Vendor ID: 0x103C
Sub-system ID: 0x280A
I just installed Qnx 6.3.2 on this computer and I need the ethernet
access to work. I first realized that I had a problem when I looked for
an ethernet device under the Network and there was nothing, running
'ifconfig' just brings up 'lo0'.
Any help on this is deeply appreciated.
Sharath
Networking Drivers
http://community.qnx.com/sf/go/post11547
Re: Network adapter - PCI Express - integrated Ethernet Controller(s) Broadcom BCM5755
08/08/2008 11:30 AM
post11571
> Its an integrated NIC, when I try pci and pci -v I dont see the adapter listed
> anywhere. I only see ATI and AMD devices, no reference to broadcom. Its
> supposed to be an integrated PCI-express controller, is there a different
> command for that?
Try pci -n 100 -v
