driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/24/2008 1:25 PM
post10955
I have implemented a BCM switch driver using io-net. When try to port the driver to work with io-pkt-v4, only one
interface is configured. Would appreciate very much extending help on this.
Details are in the following.
Sherry
After driver is activated multiple instances of interfaces is configured.
io-net -d bcm5691 mac=001faaffeedd -p tcpip
If use io-net I got the following
ifconfig
en4: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ee:dd
en4-1: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ee:f0
en4-11: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ee:fb
en4-12: flags=802<BROADCAST,SIMPLEX> mtu 1500
address: 00:1f:aa:ff:ee:fc
io-pkt-vr4 -d bcm5691 mac=001faaffeedd -p tcpip prefix=/alt
If use the io-pkt,
ifconfig
en0: flags=802<BROADCAST,SIMPLEX> mtu 1500
The bcm driver I implement send one
io_net_msg_dl_advert_t message with _IO_NET_MSG_DL_ADVERT type
for each interface.
Re: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/24/2008 1:44 PM
post10957
On Thu, Jul 24, 2008 at 01:25:58PM -0400, Sherry Chen wrote:
> Regards,
> Sherry
You should call dev_attach() for each interface.
dev_attach() takes a struct cfattach as one of its args
which it uses to allocate a per instance structure of size
(struct cfattach *)->ca_devsize which it then passes to the
(struct cfattach *)->ca_attach() callout.
So in short make sure struct cfattach is set up correctly
and call dev_attach() for each instance.
07/24/2008 4:28 PM
post11015
dev_attach?
I am using io-net. Do I need to link to io-pkt library for this? Appreciate an example.
07/24/2008 4:32 PM
post11016
On Thu, Jul 24, 2008 at 04:28:37PM -0400, Sherry Chen wrote:
> dev_attach?
In your original message you said you were trying to port an io-net
driver to io-pkt. See any of the sys/dev/* or sys/dev_qnx/* drivers
in the networking reopsitory for examples.
Or am I missing something?
RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/24/2008 4:35 PM
post11017
I'm a little confused as well. Just to re-cap what I think the situation
is...
You currently have an io-net driver. This driver works with io-net and
all interfaces are created as expected.
You want to use this driver with io-pkt and the shim. (This means that
you aren't modifying the driver and want it to work as is with io-pkt
+shim). When you start the driver under io-pkt only one interface
appears.
Is that correct?
The interfaces that are being reported by the io-net driver
are very strange. This doesn't seem to be a standard implementation
(I'd expect to see en4, en5, en6, etc.) Why is this?
The other thing is that I see that you have the "prefix=/alt" tcpip
option,
Just to confirm, are you running ifconfig against the prefix as well
SOCK=/alt ifconfig?
Robert.
Sent: Thursday, July 24, 2008 4:29 PM
To: drivers-networking
Subject: Re: driver with multiple interfaces (move from io-net
dev_attach?
Networking Drivers
http://community.qnx.com/sf/go/post11015
Re: RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/24/2008 4:46 PM
post11020
Sorry that I stated my problem wrong. You are right, I used io-pkt+shim.
I created the en4-1... en4-12 interface names and passed the name when I send the advertise message for each interface.
export SOCK env variable when I invoke ifconfig.
I tried SOCK=/alt just now. The result is the same.
Sherry
> is...
> appears.
> Is that correct?
> option,
> SOCK=/alt ifconfig?
> Robert.
> From: Sherry Chen [mailto:schen@taseon.com]
> dev_attach?
> Networking Drivers
07/25/2008 8:20 AM
post11054
There's a check in the shim's (io_net_self_t *)->reg() callout
that the registrant's (io_net_registrant_t *)->top_type is
"en". If you check the return code from the reg callout you'll
probably see that it's failing. The shim only supports ethernet
("en") devices so that's probably your mininal porting effort.
07/25/2008 11:29 AM
post11079
> -seanb
I checked my code that top_type is "en". I have trouble using the debugger, the code break in code in my devn_bcm5681.so
but not devnp-shim.so.
I traced the code with io-pkt-v4 to the point when devnp-shim is loaded.
(i.e. nw_dl.c hdl = nw_dlopen(IONET_SHIM_NAME,
RTLD_WORLD | RTLD_GROUP);
However, the code will not step into shim area.
(i.e. nw_dl.c ret = (*dentry->drvr_init)(hdl, iopkt, string);
I have trouble using the debugger with sharedlibrary for long time. The debugger sometime will break for me and
sometime will not.
Do not know how to reset the debugger to start scratch.
RE: RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/25/2008 9:08 AM
post11056
> I used io-pkt+shim.
Looking at the source to the shim, you should
call the ion->reg() function for EACH of your
interfaces. Are you calling it just once?
aboyd
Re: RE: RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/25/2008 11:41 AM
post11080
> > I used io-pkt+shim.
> aboyd
I called ion->reg only once for the BCM5691 device, And I invoke ion->tx_up for every port on the BCM5691 device (i.e.
13 times).
bcm5690->ion->tx_up(bcm5690->reghdl, npkt, 0, 0, bcm5690->cell, bcm5690->endpoint, i)
where npkt sends io_net_msg_dl_advert_t *ap message.
Do I need to call ion->reg for each port for io-pkt?
Sherry
RE: RE: RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/25/2008 11:46 AM
post11082
From: Sherry Chen [mailto:community-noreply@qnx.com]
I don't think that's going to work with io-pkt
Yup!
aboyd
Re: RE: RE: RE: driver with multiple interfaces (move from io-net environment to io-pkt with shim)
07/25/2008 2:59 PM
post11101
> Yup!
> aboyd
Thanks very much, I shall give it a try.
Sherry
07/31/2008 11:31 AM
post11284
07/24/2008 4:35 PM
post11018
> dev_attach?
> example.
Sorry, my question was not clear. I try to use io-pkt through shim. Is there a way to make it work?
