Question regarding PPP Performance.
06/21/2008 2:30 AM
post9500
I'm planning to measure ppp performance.
I want to measure network throughput between two PCs, they are connecting each other using ppp connection with a cross
serial cables.
I've measured test result with io-net and io-pkt.
With io-net,
I used commands like below.
ppp server side : pppd /dev/ser1 115200 10.100:10.200
ppp client side : pppd /dev/ser1 115200 debug updetach
Then two PCs can have IP address for 10.100 and 10.200, and they can talk each other.
PC acts as ppp server starts ftp server using inetd.
PC acts as ppp client starts ftp client to connect ftp server.
After login in to ftp server, ftp client tried to get a file from ftp server.
The file size is about 700MB.
After ppp client finished to download the file from the server, ftp clients shows me the average throughput.
The average throughput is about 10KB/s.
Is there anyone who can confirm that 10KB/s is correct or not.
(This is the first question.)
With io-pkt(revision is 409),
I used the same configurations for two PCs.
When ppp client starts to download the file from ftp server,
thers is some error message in ftp client like below, and ftp client closed connection with ftp server.
"tp: netin : No such process"
How can I solve this problem? (this is the second question.)
3. How can I make a ppp connection with baud rate 921600?
I tried to make a ppp connection with baud rate 921600, but I failed.
ppp client sent a request to a server, but ppp client can't receive a response from ppp server.
"qtalk" is not working with -b 921600 option to change baud rate of serial port.
"pppd" is also not working with 921600 baud rate.
Thanks in advance.
RE: Question regarding PPP Performance.
06/21/2008 10:02 AM
post9503
10KB/s sound about right. The data is being sent over a 115200kb/s
link. There's overhead associated with RS-232 (start/stop/parity bits),
PPP framing and IP encapsulation that reduces the actual throughput.
With regards to io-pkt, I'll try out FTP on Monday and let you know what
I find. I take it that basic communication is now working OK for you?
The underlying hardware has to be able to support the baud rate that PPP
passes to it. I don't think that the serial ports in standard PCs allow
you to go above 115200. Certainly if qtalk doesn't work, PPP won't.
Robert.
Sent: Saturday, June 21, 2008 2:30 AM
To: drivers-networking
Subject: Question regarding PPP Performance.
connecting each other using ppp connection with a cross serial cables.
With io-net,
talk each other.
server.
serial port.
Thanks in advance.
Networking Drivers
http://community.qnx.com/sf/go/post9500
Re: RE: Question regarding PPP Performance.
06/23/2008 7:30 AM
post9508
I found that it can't support higher baud rate than 115200 in standard PCs.
Then is there any possible device (e.g. usb to serial dongle) in QNX using higher baud rate?
I got another problem with ppp connection.
I run ppp server with "pppd /dev/ser1 115200 10.100:10.200", and ppp client with command "pppd /dev/ser1 115200 debug
updetach".
Finally, ppp connection was established between two PCs, but ppp interfaces in two PCs doesn't have a proper IP address.
So I need to allocate IP address to ppp interface. (e.g. ifconfig ppp0 10.100 10.200)
But with io-net ppp interfaces in two PCs has IP address after ppp connection.
Can you check this issue?
Thanks.
> Robert.
> From: Jongpil Won [mailto:skypiri@lge.com]
> With io-net,
> talk each other.
> server.
> serial port.
> Thanks in advance.
> Networking Drivers
06/23/2008 10:56 AM
post9522
> higher baud rate?
Hmm...
I think the question should be, WHAT hardware are you going to use, to support "921600" baudrate? Is it a special chip?
Is it a USB to Serial dongle?
Then a proper driver is needed to handle the hardware.
RE: RE: Question regarding PPP Performance.
06/23/2008 11:19 AM
post9524
You can google
"high speed" serial QNX
And end up with some useful information for PCI cards that support high
speed RS-232 / RS-422,485 modes of operation that come with QNX drivers.
There seem to be a number of vendors which provide such support.
Robert.
Sent: Monday, June 23, 2008 10:56 AM
Subject: Re: RE: Question regarding PPP Performance.
PCs.
using
> higher baud rate?
Hmm...
support "921600" baudrate? Is it a special chip? Is it a USB to Serial
dongle?
Networking Drivers
http://community.qnx.com/sf/go/post9522
06/23/2008 6:51 PM
post9542
Hello:
I've been trying Rev 409 and don't seem to see the IP address problem.
However, I did see the "ftp: netin : No such process" and found it to be
some sort of strange optimization issue that was causing the stack to
crash. It was resolved by adding a volatile declaration. Rev 410
contains the fix.
I did see the occasional problem with flow control (probably because of
my cabling), so disabling flow control for the serial port might also be
useful. On both sides:
stty -ihflow -ohflow < dev/ser1
As a side note, it looks like io-pkt has compression capability that
io-net doesn't because I was getting 23.5 KB/s through the link.
Hope that helps and thanks for reporting the problem!
Robert.
Sent: Monday, June 23, 2008 7:31 AM
PCs.
client with command "pppd /dev/ser1 115200 debug updetach".
10.100 10.200)
connection.
Thanks.
bits),
what
PPP
allow
> Robert.
> With io-net,
> talk each other.
> server.
> How can I solve this problem? (this is...
06/24/2008 3:17 PM
post9628
Just as a follow up to this one, this looks suspiciously like a compiler
optimization bug since the volatile shouldn't be needed. We're going to
leave it in for the time being because it does fix the problem. Another
option is to simply use the 3.3.5 compiler which doesn't result in the
crash occurring.
Sent: Monday, June 23, 2008 6:52 PM
To: 'post9508@community.qnx.com'
Subject: RE: RE: Question regarding PPP Performance.
Hello:
contains the fix.
Robert.
PCs.
10.100 10.200)
connection.
Thanks.
bits),
what
PPP
allow
> Robert.
> With io-net,
> talk each other.
> server.
> The average throughput is about...
