Installing and running e1000 driver on QNX 6.5.0
10/25/2023 4:34 PM
post122406
I have a new x86 computer for an existing system. I did a fresh install of 6.5.0 and then applied the SP 1 update.
Everything appears to work except the NICs. I see the NICs in the list of devices using pci -vvv. The NICs show as
8086:1533 and 8086:153a These are the i210 and i217 chips. I've tried several of the drivers from the internet and all
except the original abort with a core dump when I do io-pkt-v4-hc -de1000. Is there anything else I need to do other
than installing 6.5.0, applying the SP1 update, and copying in the new driver to /lib/dll? What is the latest driver?
I did install a copy of 7.1 and it was able to see both NICs fine. Am I missing something here?
