Making Ethernet interface up/down from io-pkt
03/06/2023 9:24 AM
post122156
In my application, in a specific scenario, I need to put the tsec0 interface down, and should make tsec1 up. This part
should be executed from QNX 'iopkt' TCP/IP stack subsystem. I tried calling the below command from there...
system ("ifconfig tsec0 down");
But when I ran this program, the device got restarted with the following message "SpvAbort SpvTaskTimeout task UDP"
Later I searched for options through 'ioctl 'command. But I didn't get any direct options. Instead I saw few options to
delete/add interface addresses. I tried with the below one to remove the IPI from tsec0 interface.
qnw_iface_list[0].if_net->if_ioctl (qnw_iface_list[0].if_net, SIOCDIFADDR, (caddr_t)&ifmr);
But this one also didn't help. Even though the command got executed, didn't find any change in device behavior. I was
still able to ping tsec0.
Here I need the guidance on how to make the ethernet interface down/up programmatically from 'iopkt' subsystem. I am
pretty new to QNX world, so pls bear with my ignorance
